No sound BH image 2.0.5
cenobite
Hi there !
I'm wonder why I don't have sound in some channels ? I had nothing to do some days ago and i wanted to test the new BH image. After upgrading everything worked ok, until I found some channels with no sound. I tried to change the DD downmix, but nothing. Some channels only have one audiotrack, so there isn't much to do. Is there any more audio configuration in this image ? I have the VU+ Duo and I now downgraded to BH 1.7.3 and still the same problem. And I can't remember what version I had before I upgraded, but it's an old one. Back then I didn't have this problem. Any pointers ?
bogdanm
Moderator
You have posibility setup prefered your language in Auto Language selection setting to see this menu push 2 time blue bouthons.
I have setup in my box Polish ; English ; Italy language and all work good if image find polish language setup his if no find loking more and if find on chanell english language setup him.
cenobite
I haven't looking through the whole channel list, but it would be great to have my Canal Digital Nordic subscription to work properly. The odd thing in one specific channel is Animal Planet. In HD I got sound but no picture, and in other Animal Planet channel I got picture but no sound. Most channels seems to have multiple soundtracks settings while others only have 1 alternative (usually MPEG). So there is not much to change rly... Also channels like Viasat 4 and MAX seems to have same issue (only 1 soundtrack, picture but no sound...) I also have some other questions, but they are prohibited to speak of.. So, I try this one: Something wrong with my Common Iterface ?
angelofsky1980
BlackHole Driver Specialist
You should try to verify if your CI should be upgraded via satellite or PC.
angelofsky1980
Thank you, I will try to do that :)
I will post back to you with results.
Remember also that can be a problem with CI and your subscription. Not all CIs allow to view HD content. I think there can be a similar problem also with audio tracks different than MPEG (like AC3/DD)
