No Sound on NatGeo Wild HD on Eurobird 9.0E (12054H)
frankie
Hi all!
Recently Hello HD (CaID 0x0BAA) added NatGeo Wild HD on Eurobird 9A (9.0E) - 12054.00 H - DVB-S2 (8PSK) - 27500 2/3, but there is no sound on Hungarian Audio (Audio PID: 0x1DBC). Interestingly all other Audio PID-s (English, Russian, Turkish, Bulgarian, Nederlands) working. I checked with other Octagon 1008SE STB and Hungarian Audio PID works as expected. The I tried changing CaPID from 33 to 34 in stream and Sound appeared, but then video disappeared.
BH 1.6.6
Anyone experiencing similar problem with other Channels?
Not sure why there is this problem, but BH 1.6.6 is an old image now, and it's on the old kernel.
You would be much better off updating to BH 1.7.2 or the new BP image.
Both should not only fix the problem you have, but also speed your box up too.
You would need to update the cfe on your Duo too.
Audio problem not the firmware bug.
This channel video ECM and Hungarian Audio ECM not equal. (Multi ECM)
Card reader program not supported this separated ECM mode.
Sorry for my bad english.
