No sound on video clips
nqkvotamime
With the images of BlackHole I do not sound on 1/2 from my videos that are no problem play on my old dreambox. I tested all 12-13 images for DUO2 and only on BlackHole , PersianEmpire and images of VTI - i have no sound.
I noticed that Vu+ not support and mp4 files with OGG sound.
Here's information on random clip in which no sound :
Format                        : Matroska
Format version                : Version 1
File size                      : 420 MiB
Duration                      : 3mn 36s
Overall bit rate              : 16.2 Mbps
Encoded date                  : UTC 2013-07-21 09:25:51
Writing application            : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
Writing library                : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                        : AVC
Format/Info                    : Advanced Video Codec
Format profile                : High@L5.0
Format settings, CABAC        : No
Format settings, ReFrames      : 1 frame
Codec ID                      : V_MPEG4/ISO/AVC
Duration                      : 3mn 36s
Nominal bit rate              : 16.0 Mbps
Width                          : 1 920 pixels
Height                        : 1 080 pixels
Display aspect ratio          : 16:9
Frame rate mode                : Constant
Frame rate                    : 25.000 fps
Color space                    : YUV
Chroma subsampling            : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)            : 0.309
Writing library                : x264 core 116 r2019 9cc407d
Encoding settings              : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=16000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Default                        : Yes
Forced                        : No
Audio
Format                        : AAC
Format/Info                    : Advanced Audio Codec
Format profile                : Main
Codec ID                      : A_AAC
Duration                      : 3mn 36s
Channel(s)                    : 2 channels
Channel positions              : Front: L R
Sampling rate                  : 48.0 KHz
Compression mode              : Lossy
Default                        : Yes
Forced                        : No
Sorry for my bad english
This clip play on my vu duo 2 with other images inc. Original image 2.1 , but with BlackHole and VTi no sound . May be the problem is in the blackhole image?
Edit: For OGG I made a request to Support on Vu+
Well, Matroska with AAC, but what AAC? Bitrate?... Can you give me more info's, maybe test file too?
You have tried with 3 images... BH, VTI and official 2.1.
One of them have sound during playback?
Оnly the three listed above images no sound.
On the openATV,openPLI,openViX,OpenLD,Original2.1,PBNigma,PowerOfDreams,Zebradem,OpenSPA,SatdreamsGR I have sound.
May be in BlackHole,VTi,PersianEmpire missing some codecs?
Ru dream - not tested
If the latest official OpenVuplus image has sound mean the code modification will be inserted also into images based on that code (like BH and VTI).
