No standby for external USB Disk, can BH Team help?
tapai
Hi all,
I'm using an external USB Disk (with its own / separate power supply) connected to my Vu+Solo.
In order for me to put it in Standby mode with 1.7.x images, the workaround I have found is the following plugin:
[B]enigma2-plugin-extensions-hddsleep_1.70_mipsel.ipk.tar.gz[/B]
I would like to update to 2.0.2 image, I was just testing it but unfortunalety, it seems that this issue is still here and I don't find any workaround (no mips32el version of hddsleep plugin).
During my tests (using 2.0.2 rev. C), I tried many settings (mount as media/hdd, media/usb... along with many standby delays...) but no way.
Could BH Team help, could you please include a "hddsleep-like" feature natively in your wonderful image? In advance, many thanks for your help.
Hi all,
I cannot test for you , so you can test and remove if not working.
Copy my file to tmp and install with
green>>yellow>manually install Bh packages
but here is old plugin from author @ims converted for BH OE2.0
enigma2-plugin-extensions-hddsleep_1.70 OE 2.0
@tapai...did you try Menu>Blackhole Apps>Harddrive Settings?
Oh, i didn't know that there is such setting.
I never need this, and i'm working with linux so first thing is setup this via command line :)
Thanks for this.
