No transcoding possible in Duo2 BH2.1.6.1
Rui Cardoso
Hi,
I would appreciate any help or feedback from you guys.
I could never get my Duo2 single DVB-C tuner w/ BH2.1.6.1 (flashed) to work with the Transcoded stream (normal channel stream works OK).
No matter what settings (already seen in previous threads the settings) I put in the Transcoding plugin, I cannot get it to work. On the "client" side Android/PC, whatever with any App/Program (copy pasting channel link w/ Xcoding port, etc)used it simply does not decode it... just presents a blank black screen in all of them...
The full stream is actually not getting to the receiver. For example in my PC I see spikes of data comming through but not a "stable" flow of data... though, the decoders identify the 2 streams (áudio+video), the h264 stream, frame rate, resolution, AAC áudio etc but show nothing...
I wonder if this is some issue with the transtreamproxy (it does start as I can see 2 instances running in Duo2 when I start the transcoded stream request)? or with some HW encoder issue in my STB?!
Have you got any ideas or can direct me to some info on debugging this?
I really bought this piece of HW due to the transcoding function embeeded and I cannot get it to work,...
General Details of my box below. Any help appreciated! Thks in advance!
Brand: Vu+
Model: Duo²
Chipset: 7424
Frontprocessor Version: 0
Total Memory: 1240732 kB
Free Memory: 1121804 kB
System OE: OpenVuplus 2.1
Distro: Black Hole
Firmware version: BlackHole 2.1.6.
Driver date: 3.13.5-20150511.r1
Kernel version: 3.13.5
Gui version: 2015-05-20-master
Tuner A: Vuplus DVB-C NIM(CXD1978) (DVB-C)
