No USB TDT Driver in OBH
Nash
Hi,
Firstly thank you very much to BH Team por OpenBlackHole Image it works great! :)
I can't get TDT Drivers for my USB TDT Tuner, it is Aver TV Volar Green HD (A385) and it worked brilliant with BlackHole 2.1.6.1, could I have the drivers for recognise my TDT tuner in Open BlackHole Images?
Thanks in advance!
P.S.- I'm on Vu+ Duo2
I have my A385 working again with OpenBlackHole! :)
opkg update
opkg install kernel-module-tda18218
opkg install kernel-module-mxl5007t
opkg install kernel-module-tua9001
opkg install kernel-module-af9033
opkg install kernel-module-dvb-usb-af9035
Unplug and plug again your tuner and restart gui, I hope that this bug will be fixed in the next OpenBlackHole build.
opkg update
It's not a bug but into the image configuration in build phase there are not mentioned a LOTS of things .... We'll work to minimize the user interactions for DVB USB devices in the same way BH images does already.
