Hi all, as title says i have a question, i have a "vu+duo 2" DVB-C cable box, im moving to a new place that have satellite, since my box is cable, is it possible to use this tuner to work with satellite? changing only the connector on the cable?
They are easy to fit, a bit like fitting a computer graphics card, they just slot in, and out. Within 5 minutes you should have 2, working, satellite tuners, and a spare cable card, if you ever move again, or you can sell it.
