Not Support DTS Audio
ok what i mean is. when i play a mkv movie with DTS sound i don` t have sound on my sound system. Dolby Digital 5.1 is not Problem. only DTS. so when i activate dolby digital downmix then i have sound but only stereo.... but i mus say i have only HDMI from Receiver to TV and from Tv to soundsystem a toslink cable..
I've tested MKV with only DTS audio tracks with Duo2 (and other Vu+ boxes too) with the ampli in my signature with HDMI connectio and all works properly.
About optical connection I should re-test the situation but I'm pretty sure that all works regularly.
If you enable downmix it's clear that the sound is downgraded to Stereo only.
so i tried to get sound on Tv or my audio system .. But when i play a mkv file with dts audio i haven`t sound..so Dolby Digital 5.1 is not Problem.
Greetings Stevie
Greetings Stevie
Can you use ONLY HDMI connection between your box, your ampli and your TV set?
So, I have the same problem on DUO2, no DTS sound from toslink. AC3 is fine.
The exact same setup did have DTS on my old DUO.
