Notepad++ v6.1.5
a911
The BH Lover
Notepad++ v6.1.5
fixed bugs:
1.Fix a html tag match freezing issue.
2.Fix the sidebar splitter failed in Windows 8 issue.
3.Fix un regression: folding/unfolding performance issue.
4.Fix tab context menu in the other localization regression due to adding new command "Reload".
5.Fix lower/UPPER case on selected text which contains NULL characters.
6.Fix wrap/unwrap line position not being kept bug.
7.Fix xml syntax highlighting broken because of php preprocessor instruction inside.
8.Fix a GUI bug which shows empty tab row while closing a last tab in a row (in the multi-line tab mode).
Good Tool 2Read Crash logs,,and more!
A real "Must Have" tool.
Once associated with Total Commander, you can do whatever you want into the vuplus :yes:
