notification when recording?
lefjomp
is there a way to get some sort of Visual notification when i record a program on this image?
i noticed that theres a setting to get the Clock to blink when the receiver is recording,but it doesnt work.
is it possible to get some sort of notification when recording?
I do not know what kind of notification you want.
It is present in the LCD and OSD
i just want some kind of flashing or blinking on the front, just so i can see that im recording, but i cant find anything like that.
Which receiver do you have? As @Matrix10 said, there are two places where you may find the notification marks of recording.
1. If you have a LCD sreen on your reeiver (such as Duo2 ) with BH 2.0.9, the LCD4linux plugin may do the job you want. When recording is in progress, a red mark will display on the right corner of the LCD sreen.
2. Also, there is a red flash mark on OSD. when you are watch a channel, press oky button on your remote control, you will see the red flash mark on OSD information bar.
it will very usefull to see the red blinkig notification in the tv screen without pressing any button. like camera 'Rec'
