Novice - Advantages of using KodiDirect plugin on duo2
VUNOVICE
Hi All,
I'm thinking of downloading the Kodidirect plugin for use on my Duo 2. I've never used Kodi before, what can I expect from Kodi, has the plugin got an easy to use interface etc and will it make navigating movies/Sports etc much easier.
Thanks in Advance
Ru.
Hi All,
Thanks in Advance
Ru.
What for ( kodi direct was discontinued by author ( pcd )), Duo2 can run KODI.
Thanks Nunigaia. I'm very new to this so don't know a lot. I'm running Openvix at the moment, how would I install Kodi too.
Regards
Ru.
Regards
Ru.
Sorry, but we don´t give support to images rather then BlackHole or Open BlackHole.
