NPG REAL DVB-2T
paztero1
And put in my decos, vusolose v2 and vu + uno4k the image openBH, in the two decades after putting the Af9015 driver that corresponds to that usb tdt in none works, which in the previous version if it did, Can someone please inform me if this has a solution?
The usb tdt is from the brand NPG REAL DVB-2T is dual.
I don't know your device.
Could you please follow the thread http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/ and upload here the debug file generated?
This weekend he will consider here this file that generates, and as I comment on the previous version if it will work with the driver AF9015.
Well, what is promised is debt, now in my vusolose v2 the usb tdt Npg Real Dvb-2T works well for me, but in the vu + uno4k it does not work and that is why I put the data here to see if they see where the fault is.
This tuner is identified by this data: id "15a4: 9016" NPG REAL DVB-2T = Af9015 It has 2 tuners, it is not TDT2
Box Info
Kernel: Linux vuuno4k 3.14.28-1.12 #1 SMP Wed Aug 14 16:58:21 UTC 2019 armv7l GNU/Linux
BH Ver:
USB devices
Bus 002 Device 002: ID 05e3:0612
Bus 003 Device 002: ID 0781:5571
Bus 004 Device 002: ID 05e3:0610
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0003
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 002 Device 003: ID 0480:a00c
Bus 004 Device 003: ID 0bda:8179
Bus 004 Device 004: ID 15a4:9016
Bus 004 Device 005: ID 0603:0002
Kernel Messages
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.14.28-1.12 (oe-user@oe-host) (gcc version 8.2.0 (GCC) ) #1 SMP Wed Aug 14 16:58:21 UTC 2019
[ 0.000000] CPU: ARMv7 Processor [420f00f3] revision 3 (ARMv7), cr=30c7387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: UNO4K
[ 0.000000] moving dtb from 0x0000000007628000 to 0x00000000009692f0
[ 0.000000] bmem: Reserved 637 MiB at 0x0000000017f00000
[ 0.000000] bmem: Reserved 637 MiB at 0x0000000097f00000
[ 0.000000] cma: Reserved 16 MiB at 0x0000000016400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] Normal zone: 750 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 96000 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3346 pages used for memmap
[ 0.000000] HighMem zone: 428288 pages, LIFO batch:31
[ 0.000000] MCP: Enabling write pairing
[ 0.000000] PERCPU: Embedded 8 pages/cpu @d75bd000 s9728 r8192 d14848 u32768
[ 0.000000] pcpu-alloc: s9728 r8192 d14848 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 523538
[ 0.000000] Kernel command line: root=/dev/mmcblk0p4 rootfstype=ext4 rootflags=data=journal rootwait rw coherent_pool=2M vmalloc=633m bmem=637m@383m bmem=637m@2431m
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 741276K/2097152K available (6664K kernel code, 367K rwdata, 2092K rodata, 269K init, 205K bss, 1339492K reserved, 16384K cma-reserved, 400376K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd7800000 - 0xff000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd7700000 ( 375 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0895450 (8758 kB)
[ 0.000000] .init : 0xc0896000 - 0xc08d9600 ( 270 kB)
[ 0.000000] .data : 0xc08da000 - 0xc0935e70 ( 368 kB)
[ 0.000000] .bss : 0xc0935e78 - 0xc09692f0 ( 206 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc403000, parent irq: 93)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc3e1000, parent irq: 64)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc410640, parent irq: 95)
[ 0.000000] irq_brcmstb_l2: registered L2 intc (mem: 0xfc4d1200, parent irq: 58)
[ 0.000000] Architected cp15 timer(s) running at 27.00MHz (virt).
[ 0.000003] sched_clock: 56 bits at 27MHz, resolution 37ns, wraps every 2545165795328ns
[ 0.000010] Switching to timer-based delay loop
[ 0.000263] Console: colour dummy device 80x30
[ 0.000282] Calibrating delay loop (skipped), value calculated using timer frequency.. 54.00 BogoMIPS (lpj=27000)
[ 0.000290] pid_max: default: 32768 minimum: 301
[ 0.000381] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000387] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.006084] CPU: Testing write buffer coherency: ok
[ 0.006268] CPU0: update cpu_power 1024
[ 0.006274] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.006450] Setting up static identity map for 0x65c8e8 - 0x65c940
[ 0.009062] CPU1: Booted secondary processor
[ 0.009082] CPU1: update cpu_power 1024
[ 0.009085] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009182] Brought up 2 CPUs
[ 0.009193] SMP: Total of 2 processors activated.
[ 0.009197] CPU: All CPU(s) started in SVC mode.
[ 0.009575] devtmpfs: initialized
[ 0.012973] VFP support v0.3: implementor 42 architecture 4 part 00 variant 0 rev 0
[ 0.013951] regulator-dummy: no parameters
[ 0.014181] NET: Registered protocol family 16
[ 0.015029] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[ 0.015816] cpuidle: using governor ladder
[ 0.015823] cpuidle: using governor menu
[ 0.018303] irq: no irq domain found for /rdb/interrupt-controller@f040a700 !
[ 0.018437] irq: no irq domain found for /rdb/interrupt-controller@f0417380 !
[ 0.021478] irq: no irq domain found for /rdb/interrupt-controller@f03e1a00 !
[ 0.021733] syscon f0404000.syscon: regmap [mem 0xf0404000-0xf0404523] registered
[ 0.021876] syscon f0404100.syscon: regmap [mem 0xf0404100-0xf040415b] registered
[ 0.022014] syscon f040415c.syscon: regmap [mem 0xf040415c-0xf040419b] registered
[ 0.022184] syscon f0410700.syscon: regmap [mem 0xf0410700-0xf041070b] registered
[ 0.022344] syscon f041070c.syscon: regmap [mem 0xf041070c-0xf0410713] registered
[ 0.022482] syscon f1101004.syscon: regmap [mem 0xf1101004-0xf1101403] registered
[ 0.022612] syscon f1181004.syscon: regmap [mem 0xf1181004-0xf1181403] registered
[ 0.022744] syscon f0404080.syscon: regmap [mem 0xf0404080-0xf0404083] registered
[ 0.022867] syscon f04040a4.syscon: regmap [mem 0xf04040a4-0xf04040a7] registered
[ 0.022990] syscon f03e0154.syscon: regmap [mem 0xf03e0154-0xf03e0157] registered
[ 0.023112] syscon f03e0354.syscon: regmap [mem 0xf03e0354-0xf03e0357] registered
[ 0.023257] syscon f03e0400.syscon: regmap [mem 0xf03e0400-0xf03e0403] registered
[ 0.023801] irq: no irq domain found for /rdb/interrupt-controller@f0417380 !
[ 0.024326] syscon f03e2400.syscon: regmap [mem 0xf03e2400-0xf03e27ff] registered
[ 0.024459] syscon f0452000.syscon: regmap [mem 0xf0452000-0xf04520ff] registered
[ 0.024744] No ATAGs?
[ 0.024761] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.024765] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.024940] Broadcom Brahma-B15 readahead cache at: 0xfc3e2478
[ 0.039605] bio: create slab <bio-0> at 0
[ 0.040286] SCSI subsystem initialized
[ 0.040495] libata version 3.00 loaded.
[ 0.040866] usbcore: registered new interface driver usbfs
[ 0.040938] usbcore: registered new interface driver hub
[ 0.041028] usbcore: registered new device driver usb
[ 0.041153] Linux video capture interface: v2.00
[ 0.041611] pps_core: LinuxPPS API ver. 1 registered
[ 0.041615] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.041665] PTP clock support registered
[ 0.042277] Advanced Linux Sound Architecture Driver Initialized.
[ 0.043019] cfg80211: Calling CRDA to update world regulatory domain
[ 0.043508] brcm-pci f0460000.pcie: adjusting to legacy (broken) pcie DT
[ 0.043692] brcm-pci f0490000.pcie: adjusting to legacy (broken) pcie DT
[ 0.144011] brcm-pci f0460000.pcie: link down
[ 0.244034] brcm-pci f0490000.pcie: link down
[ 0.244081] Switched to clocksource arch_sys_counter
[ 0.244267] FS-Cache: Loaded
[ 0.252610] thermal thermal_zone0: failed to read out thermal zone 0
[ 0.252689] NET: Registered protocol family 2
[ 0.253065] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.253111] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.253151] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.253223] TCP: reno registered
[ 0.253231] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.253245] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.253364] NET: Registered protocol family 1
[ 0.253556] RPC: Registered named UNIX socket transport module.
[ 0.253560] RPC: Registered udp transport module.
[ 0.253564] RPC: Registered tcp transport module.
[ 0.253567] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.253574] PCI: CLS 0 bytes, default 64
[ 0.253807] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.254892] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.255562] bounce pool size: 64 pages
[ 0.255906] FS-Cache: Netfs 'nfs' registered for caching
[ 0.256046] NFS: Registering the id_resolver key type
[ 0.256091] Key type id_resolver registered
[ 0.256101] Key type id_legacy registered
[ 0.256115] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.256122] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.256322] FS-Cache: Netfs 'cifs' registered for caching
[ 0.256368] Key type cifs.spnego registered
[ 0.256544] fuse init (API version 7.22)
[ 0.256686] SGI XFS with security attributes, realtime, large block/inode numbers, no debug enabled
[ 0.256941] msgmni has been set to 697
[ 0.257654] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.257661] io scheduler noop registered
[ 0.257665] io scheduler deadline registered
[ 0.257683] io scheduler cfq registered (default)
[ 0.257912] brcm-gisb-arb f0400000.gisb-arb: registered mem: fc400000, irqs: 258, 259
[ 0.273651] brcm-waketimer f0417580.waketimer: registered, with irq 260
[ 0.273952] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.275344] f040a900.serial: ttyS0 at MMIO 0xf040a900 (irq = 107, base_baud = 5062500) is a 16550A
[ 1.090101] console [ttyS0] enabled
[ 1.094008] f040a940.serial: ttyS1 at MMIO 0xf040a940 (irq = 108, base_baud = 5062500) is a 16550A
[ 1.103347] f040a980.serial: ttyS2 at MMIO 0xf040a980 (irq = 109, base_baud = 5062500) is a 16550A
[ 1.115518] loop: module loaded
[ 1.119291] ahci brcmstb-ahci.0: can't get clock
[ 1.124007] ahci brcmstb-ahci.0: SSS flag set, parallel bus scan disabled
[ 1.141094] ahci brcmstb-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 1.149724] ahci brcmstb-ahci.0: flags: 64bit ncq sntf stag pm clo pmp slum part
[ 1.159185] scsi0 : ahci_platform
[ 1.162832] scsi1 : ahci_platform
[ 1.166373] ata1: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x100 irq 91
[ 1.174308] ata2: SATA max UDMA/133 mmio [mem 0xf045a000-0xf045aa9b] port 0x180 irq 91
[ 1.183525] spi_brcmstb f03e3400.spi: 1-lane output, 3-byte address
[ 1.189922] spi_brcmstb f03e3400.spi: master is unqueued, this is deprecated
[ 1.197244] m25p80 spi32766.0: found mx25l3255e, expected m25p80
[ 1.203281] m25p80 spi32766.0: mx25l3255e (4096 Kbytes)
[ 1.208537] 5 ofpart partitions found on MTD device spi32766.0
[ 1.214383] Creating 5 MTD partitions on "spi32766.0":
[ 1.219533] 0x000000000000-0x000000200000 : "flash0.bolt"
[ 1.225612] 0x000000200000-0x000000210000 : "flash0.macadr"
[ 1.231793] 0x000000210000-0x000000220000 : "flash0.nvram"
[ 1.237882] 0x000000220000-0x000000230000 : "flash0.devtree"
[ 1.244149] 0x000000000000-0x000000400000 : "flash0"
[ 1.250753] libphy: Fixed MDIO Bus: probed
[ 1.255536] bcmgenet f0b00000.ethernet: GENET 4.5 EPHY: 0x1001
[ 1.272086] libphy: bcmgenet MII bus: probed
[ 1.292094] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.297561] e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
[ 1.303414] e1000e: Copyright(c) 1999 - 2013 Intel Corporation.
[ 1.309870] xhci-brcm: xHCI BRCM driver
[ 1.313807] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
[ 1.319640] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 1
[ 1.327737] xhci-brcm f0471000.xhci_v2: irq 149, io mem 0xf0471000
[ 1.334464] hub 1-0:1.0: USB hub found
[ 1.338243] hub 1-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 1.345505] xhci-brcm f0471000.xhci_v2: xHCI Host Controller
[ 1.351317] xhci-brcm f0471000.xhci_v2: new USB bus registered, assigned bus number 2
[ 1.359635] hub 2-0:1.0: USB hub found
[ 1.363412] hub 2-0:1.0: 2 ports detected
[ 1.367793] ehci-brcm: EHCI BRCM driver
[ 1.371732] ehci-brcm f0470300.ehci_v2: EHCI Host Controller
[ 1.377560] ehci-brcm f0470300.ehci_v2: new USB bus registered, assigned bus number 3
[ 1.395527] ehci-brcm f0470300.ehci_v2: irq 145, io mem 0xf0470300
[ 1.407090] ehci-brcm f0470300.ehci_v2: USB 2.0 started, EHCI 1.00
[ 1.413741] hub 3-0:1.0: USB hub found
[ 1.417519] hub 3-0:1.0: 1 port detected
[ 1.421657] ehci-brcm f0470500.ehci_v2: EHCI Host Controller
[ 1.425095] ata2: SATA link down (SStatus 0 SControl 300)
[ 1.432912] ehci-brcm f0470500.ehci_v2: new USB bus registered, assigned bus number 4
[ 1.450880] ehci-brcm f0470500.ehci_v2: irq 146, io mem 0xf0470500
[ 1.463084] ehci-brcm f0470500.ehci_v2: USB 2.0 started, EHCI 1.00
[ 1.469731] hub 4-0:1.0: USB hub found
[ 1.473509] hub 4-0:1.0: 1 port detected
[ 1.477751] ohci-brcm: OHCI BRCM driver
[ 1.481674] ohci-brcm f0470400.ohci_v2: BRCM OHCI controller
[ 1.487507] ohci-brcm f0470400.ohci_v2: new USB bus registered, assigned bus number 5
[ 1.495388] ohci-brcm f0470400.ohci_v2: irq 147, io mem 0xf0470400
[ 1.556544] hub 5-0:1.0: USB hub found
[ 1.560320] hub 5-0:1.0: 1 port detected
[ 1.564446] ohci-brcm f0470600.ohci_v2: BRCM OHCI controller
[ 1.570278] ohci-brcm f0470600.ohci_v2: new USB bus registered, assigned bus number 6
[ 1.578166] ohci-brcm f0470600.ohci_v2: irq 148, io mem 0xf0470600
[ 1.639560] hub 6-0:1.0: USB hub found
[ 1.643339] hub 6-0:1.0: 1 port detected
[ 1.647569] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.654118] ehci-pci: EHCI PCI platform driver
[ 1.658660] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.664861] ohci-pci: OHCI PCI platform driver
[ 1.669593] usbcore: registered new interface driver usb-storage
[ 1.675787] mousedev: PS/2 mouse device common for all mice
[ 1.681761] i2c /dev entries driver
[ 1.685617] IR NEC protocol handler initialized
[ 1.690188] IR RC5(x) protocol handler initialized
[ 1.690192] usb 2-2: new SuperSpeed USB device number 2 using xhci-brcm
[ 1.701635] IR RC6 protocol handler initialized
[ 1.706204] IR JVC protocol handler initialized
[ 1.710765] IR Sony protocol handler initialized
[ 1.715408] IR RC5 (streamzap) protocol handler initialized
[ 1.715414] usb 2-2: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 1.729970] IR SANYO protocol handler initialized
[ 1.734697] IR MCE Keyboard/mouse protocol handler initialized
[ 1.741005] brcmstb_thermal f04d1500.thermal: registered AVS TMON of-sensor driver
[ 1.748975] cpufreq_cpu0: failed to get cpu0 regulator: -19
[ 1.754923] sdhci: Secure Digital Host Controller Interface driver
[ 1.761136] sdhci: Copyright(c) Pierre Ossman
[ 1.761226] hub 2-2:1.0: USB hub found
[ 1.769266] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.769271] hub 2-2:1.0: 4 ports detected
[ 1.780155] mmc0: no vqmmc regulator found
[ 1.784273] mmc0: no vmmc regulator found
[ 1.819087] mmc0: SDHCI controller on f03e0200.sdhci [f03e0200.sdhci] using ADMA
[ 1.828783] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.836585] usbcore: registered new interface driver usbhid
[ 1.842178] usbhid: USB HID core driver
[ 1.846648] TCP: cubic registered
[ 1.852068] NET: Registered protocol family 10
[ 1.861030] NET: Registered protocol family 17
[ 1.867718] Key type dns_resolver registered
[ 1.874116] Registering SWP/SWPB emulation handler
[ 1.879368] regulator-dummy: disabling
[ 1.883195] usb 3-1: new high-speed USB device number 2 using ehci-brcm
[ 1.894154] ALSA device list:
[ 1.897139] No soundcards found.
[ 1.900795] Waiting for root device /dev/mmcblk0p4...
[ 1.933731] mmc0: BKOPS_EN bit is not set
[ 1.944204] mmc0: new high speed MMC card at address 0001
[ 1.949972] mmcblk0: mmc0:0001 4FPD3R 3.64 GiB
[ 1.954605] mmcblk0boot0: mmc0:0001 4FPD3R partition 1 4.00 MiB
[ 1.960623] mmcblk0boot1: mmc0:0001 4FPD3R partition 2 4.00 MiB
[ 1.966630] mmcblk0rpmb: mmc0:0001 4FPD3R partition 3 512 KiB
[ 1.975463] mmcblk0: p1 p2 p3 p4
[ 1.981493] mmcblk0boot1: unknown partition table
[ 1.987005] mmcblk0boot0: unknown partition table
[ 2.006637] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 2.012887] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
[ 2.022701] scsi2 : usb-storage 3-1:1.0
[ 2.040564] EXT4-fs (mmcblk0p4): warning: maximal mount count reached, running e2fsck is recommended
[ 2.050174] EXT4-fs (mmcblk0p4): recovery complete
[ 2.055397] EXT4-fs (mmcblk0p4): mounted filesystem with journalled data mode. Opts: data=journal
[ 2.064313] VFS: Mounted root (ext4 filesystem) on device 179:4.
[ 2.072939] devtmpfs: mounted
[ 2.076194] Freeing unused kernel memory: 268K (c0896000 - c08d9000)
[ 2.129124] usb 4-1: new high-speed USB device number 2 using ehci-brcm
[ 2.261320] hub 4-1:1.0: USB hub found
[ 2.265511] hub 4-1:1.0: 4 ports detected
[ 2.441935] usb 2-2.4: new SuperSpeed USB device number 3 using xhci-brcm
[ 2.460179] usb 2-2.4: Parent hub missing LPM exit latency info. Power management will be impacted.
[ 2.477725] usb-storage 2-2.4:1.0: USB Mass Storage device detected
[ 2.491049] scsi3 : usb-storage 2-2.4:1.0
[ 2.562370] usb 4-1.1: new high-speed USB device number 3 using ehci-brcm
[ 2.680823] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 2.693394] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 2.708376] usb 4-1.2: new high-speed USB device number 4 using ehci-brcm
[ 2.739499] usbcore: registered new interface driver r8188eu
[ 2.803228] Afatech DVB-T 2: Fixing fullspeed to highspeed interval: 10 -> 7
[ 2.815905] input: Afatech DVB-T 2 as /devices/rdb.3/f0470500.ehci_v2/usb4/4-1/4-1.2/4-1.2:1.1/0003:15A4:9016.0001/input/input0
[ 2.836383] hid-generic 0003:15A4:9016.0001: input,hidraw0: USB HID v1.01 Keyboard [Afatech DVB-T 2] on usb-f0470500.ehci_v2-1.2/input1
[ 2.918382] usb 4-1.3: new low-speed USB device number 5 using ehci-brcm
[ 3.011531] input: SINO WEALTH USB Composite Device as /devices/rdb.3/f0470500.ehci_v2/usb4/4-1/4-1.3/4-1.3:1.0/0003:0603:0002.0002/input/input1
[ 3.029322] scsi 2:0:0:0: Direct-Access SanDisk Cruzer Fit 1.27 PQ: 0 ANSI: 6
[ 3.042949] hid-generic 0003:0603:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SINO WEALTH USB Composite Device] on usb-f0470500.ehci_v2-1.3/input0
[ 3.058437] sd 2:0:0:0: [sda] 31266816 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 3.066720] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 3.073858] sd 2:0:0:0: [sda] Write Protect is off
[ 3.078692] sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.084620] input: SINO WEALTH USB Composite Device as /devices/rdb.3/f0470500.ehci_v2/usb4/4-1/4-1.3/4-1.3:1.1/0003:0603:0002.0003/input/input2
[ 3.087512] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 3.116358] hid-generic 0003:0603:0002.0003: input,hiddev0,hidraw2: USB HID v1.10 Mouse [SINO WEALTH USB Composite Device] on usb-f0470500.ehci_v2-1.3/input1
[ 3.130812] random: nonblocking pool is initialized
[ 3.131217] sda: sda1
[ 3.144038] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 3.504094] scsi 3:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6
[ 3.516686] sd 3:0:0:0: [sdb] 976773164 512-byte logical blocks: (500 GB/465 GiB)
[ 3.525152] sd 3:0:0:0: Attached scsi generic sg1 type 0
[ 3.531271] sd 3:0:0:0: [sdb] Write Protect is off
[ 3.536096] sd 3:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 3.536603] sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.980893] EXT4-fs (sda1): recovery complete
[ 3.987018] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.593188] sdb: sdb1
[ 5.598935] sd 3:0:0:0: [sdb] Attached SCSI disk
[ 6.130828] UDF-fs: warning (device sdb1): udf_fill_super: No partition found (2)
[ 11.409376] usb 4-1.2: dvb_usb_v2: found a 'Afatech AF9015 reference design' in warm state
[ 11.623549] usb 4-1.2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 11.633656] DVB: registering new adapter (Afatech AF9015 reference design)
[ 11.648673] DVB: Unable to find symbol af9013_attach()
[ 11.664732] usbcore: registered new interface driver dvb_usb_af9015
[ 13.668584] procmk_init
[ 13.675276] bcm_event: module license 'Proprietary' taints kernel.
[ 13.681487] Disabling lock debugging due to kernel taint
[ 17.184935] DVB: registering new adapter (_vuplus_uno4k_)
[ 17.419197] bcm7252s: hotplug_callback():
[ 17.419197] Hotplug - status.connected 1:0:1
[ 17.426485] bcm7252s: hotplug_callback():
[ 17.426485] Hotplug - connecting HDMI to display 0xe
[ 17.637097] brcm_demux_init: $Id: bcm_demux.c,v 0.7 $
[ 17.766116] [MPVR]: >> misc_pvr_init
[ 17.784501] [VID]: 6bcm7335_video_init
[ 17.872226] [AUD]: 6bcm7335_audio_init
[ 17.881381] [AUD]: >> bcm_audio_capture_init
[ 17.892150] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d4bfa000 state=d1841000 config=bf81bfd0
[ 17.928754] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 17.943071] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d4004c00 state=d1ac2800 config=bf81bfd8
[ 17.969497] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 17.977890] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d4b59000 state=d1ac2000 config=bf81bfe0
[ 18.000342] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.008993] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d402c400 state=d1ad7800 config=bf81bfe8
[ 18.032378] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.040448] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d402cc00 state=d1ad7000 config=bf81bff0
[ 18.062132] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.070070] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d49ee400 state=d1bf8800 config=bf81bff8
[ 18.091682] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.126360] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d49eec00 state=d1bf8000 config=bf81c000
[ 18.158671] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.167242] fe_cap.qam : 0, fe_cap.ofd : 0, fe_cap.satellite:1 handle=d4b5f400 state=d1403800 config=bf81c008
[ 18.193139] BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
[ 18.201599] bcm7252s: bcm7335_frontend_init(): vtuner1 : 9
[ 18.225596] BKNI_P_GetTrackAllocEntry_resize: resizing from 5376->8704
[ 18.233311] BKNI_Malloc(linuxkernel) top users:
[ 18.233311] blocks, bytes, filename:line
[ 18.242313] 1074, 234048, BSEAV/lib/utils/balloc.c:31
[ 18.291581] input: dreambox advanced remote control (native) as /devices/virtual/input/input3
[ 18.311829] [LCD]: registered
[ 18.326594] [CI]: registered ci0
[ 18.338974] [CI]: CI interface initialised
[ 18.338974]
[ 18.351455] [DFP]: registered dbox fp
[ 18.363839] [SC]: registered sci0
[ 19.807089] system_time_set wakeup mode get
[ 19.871173] system_time_set wakeup mode get 0xc4
[ 20.127151] [VID]: VIDEO_SET_STREAMTYPE 0
[ 20.131973] [VID]: VIDEO_SELECT_SOURCE 1 0
[ 20.137495] [VID]: VIDEO_PLAY 1 2 0
[ 20.147788] [VID]: VIDEO_CONTINUE 1 1
[ 20.151868] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
[ 20.429823] [VID]: VIDEO_STOP 0 1
[ 20.434224] [VID]: VIDEO_SELECT_SOURCE 0 0
[ 25.680514] EXT4-fs (sdb1): VFS: Can't find ext4 filesystem
[ 26.221607] UDF-fs: warning (device sdb1): udf_fill_super: No partition found (2)
[ 28.875041] [VID]: VIDEO_SET_STREAMTYPE 0
[ 28.879275] [VID]: VIDEO_SELECT_SOURCE 1 0
[ 28.883657] [VID]: VIDEO_PLAY 1 2 0
[ 28.892591] [VID]: VIDEO_CONTINUE 1 1
[ 28.896499] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
[ 29.172134] [VID]: VIDEO_STOP 0 1
[ 29.176584] [VID]: VIDEO_SELECT_SOURCE 0 0
[ 29.244089] f0b00000.etherne:01: Broadcom BCM7439 (2) PHY revision: 0x10, patch: 1
[ 29.255353] f0b00000.ethernet: configuring instance for internal PHY
[ 29.261836] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.217395] Bluetooth: Core ver 2.18
[ 31.232732] NET: Registered protocol family 31
[ 31.237423] Bluetooth: HCI device and connection manager initialized
[ 31.237446] Bluetooth: HCI socket layer initialized
[ 31.237454] Bluetooth: L2CAP socket layer initialized
[ 31.237500] Bluetooth: SCO socket layer initialized
[ 31.263057] libphy: f0b00000.etherne:01 - Link is Down
[ 32.486676] libphy: f0b00000.etherne:01 - Link is Up - 100/Full
[ 32.493059] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 32.968931] [VID]: VIDEO_SET_STREAMTYPE 0
[ 32.973375] [VID]: VIDEO_SELECT_SOURCE 1 0
[ 32.977693] [VID]: VIDEO_PLAY 1 2 0
[ 32.986645] [VID]: VIDEO_CONTINUE 1 1
[ 32.990871] [VID]: VIDEO_CLEAR_BUFFER 1 1 0
[ 33.265759] [VID]: VIDEO_STOP 0 1
[ 33.270158] [VID]: VIDEO_SELECT_SOURCE 0 0
[ 46.505597] [AUD]: AUDIO_SET_MUTE 0
[ 46.509701] [AUD]: AUDIO_SET_MIXER -810328440
[ 46.514196] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[ 46.519277] [AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[ 46.525918] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[ 47.261440] [AUD]: AUDIO_SET_MIXER -810328440
[ 47.265934] [AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[ 47.271015] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[ 47.277993] [AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[ 49.948393] FE tune
[ 51.489798] [AUD]: AUDIO_SELECT_SOURCE 0
[ 51.494452] [AUD]: AUDIO_SET_BYPASS_MODE 1
[ 51.499035] [AUD]: downmix 0 state : 0
[ 51.502982] [AUD]: AUDIO_PAUSE 0
[ 51.506621] [AUD]: AUDIO_PLAY 0 decoder start : 0
[ 51.512970] [VID]: VIDEO_SELECT_SOURCE 0 0
[ 51.518429] [VID]: VIDEO_GET_SIZE src w: 1280 h:720 display w:1280 h:720
[ 51.525173] [VID]: VIDEO_GET_SIZE aspect: 1 3
[ 51.529642] [VID]: VIDEO_SET_STREAMTYPE 0
[ 51.533888] [VID]: VIDEO_FREEZE 0 0
[ 51.537574] [VID]: VIDEO_PLAY 0 2 2
[ 51.546434] [VID]: VIDEO_SLOWMOTION 0 1
[ 51.550644] [VID]: VIDEO_FAST_FORWARD 0 1 0
[ 51.555144] [VID]: VIDEO_CONTINUE 0 1
[ 51.559040] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd0d8c880
[ 51.564062] [AUD]: Mute : 0
[ 51.567250] [AUD]: AUDIO_CHANNEL_SELECT 0
[ 51.795797] [VID]: VIDEO_SLOWMOTION 0 1
[ 51.800225] [VID]: VIDEO_FAST_FORWARD 0 1 0
[ 51.804927] [VID]: VIDEO_CONTINUE 0 1
[ 51.808922] [AUD]: AUDIO_CONTINUE 0 1 aph=0xd0d8c880
[ 51.813914] [AUD]: Mute : 0
[ 65.839269] [VID]: VIDEO_STOP 1 1
[ 65.843151] [AUD]: AUDIO_STOP 0
[ 65.870287] [AUD]: AUDIO_CONTINUE 0 0 aph=0x0
[ 65.874674] [AUD]: AUDIO_CONTINUE aph=0 0 0
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Name: Vuplus DVB-S NIM(45208 FBC)
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-S2
Frontend_Device: 2
NIM Socket 3:
Type: DVB-S2
Frontend_Device: 3
NIM Socket 4:
Type: DVB-S2
Frontend_Device: 4
NIM Socket 5:
Type: DVB-S2
Frontend_Device: 5
NIM Socket 6:
Type: DVB-S2
Frontend_Device: 6
NIM Socket 7:
Type: DVB-S2
Frontend_Device: 7
Modules Loaded
Module Size Used by
bluetooth 309479 4
6lowpan_iphc 9568 1 bluetooth
brcmfb 1483 3
dvb_bcm7252s 1346302 2 brcmfb
dvb_base 5516198 7 dvb_bcm7252s
bcm_event 2903 5 dvb_bcm7252s
procmk 1682 2 bcm_event,dvb_bcm7252s
dvb_usb_af9015 19395 0
dvb_usb_v2 21035 1 dvb_usb_af9015
r8188eu 584112 0
Kernel Objects
/lib/modules/3.14.28-1.12
/lib/modules/3.14.28-1.12/modules.symbols.bin
/lib/modules/3.14.28-1.12/modules.order
/lib/modules/3.14.28-1.12/modules.alias.bin
/lib/modules/3.14.28-1.12/modules.devname
/lib/modules/3.14.28-1.12/kernel
/lib/modules/3.14.28-1.12/kernel/net
/lib/modules/3.14.28-1.12/kernel/net/ieee802154
/lib/modules/3.14.28-1.12/kernel/net/ieee802154/6lowpan_iphc.ko
/lib/modules/3.14.28-1.12/kernel/net/mac80211
/lib/modules/3.14.28-1.12/kernel/net/mac80211/mac80211.ko
/lib/modules/3.14.28-1.12/kernel/net/bluetooth
/lib/modules/3.14.28-1.12/kernel/net/bluetooth/bluetooth.ko
/lib/modules/3.14.28-1.12/kernel/drivers
/lib/modules/3.14.28-1.12/kernel/drivers/mtd
/lib/modules/3.14.28-1.12/kernel/drivers/mtd/nand
/lib/modules/3.14.28-1.12/kernel/drivers/mtd/nand/nandsim.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/si2157.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/mt2060.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/mxl5007t.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/tda18218.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/fc0012.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/mxl5005s.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/qt1010.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/tua9001.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/fc0011.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/tuners/fc2580.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/dibx000_common.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/dvb-pll.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/af9033.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/af9013.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/si2168.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/dib0070.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/dvb-frontends/dib7000p.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb/dvb-usb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb/dvb-usb-cxusb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/siano
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/siano/smsusb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb-v2
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb-v2/dvb_usb_v2.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-dvbsky.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/common
/lib/modules/3.14.28-1.12/kernel/drivers/media/common/siano
/lib/modules/3.14.28-1.12/kernel/drivers/media/common/siano/smsdvb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/media/common/siano/smsmdtv.ko
/lib/modules/3.14.28-1.12/kernel/drivers/staging
/lib/modules/3.14.28-1.12/kernel/drivers/staging/rtl8188eu
/lib/modules/3.14.28-1.12/kernel/drivers/staging/rtl8188eu/r8188eu.ko
/lib/modules/3.14.28-1.12/kernel/drivers/staging/rtl8712
/lib/modules/3.14.28-1.12/kernel/drivers/staging/rtl8712/r8712u.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rtl818x
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rtl818x/rtl8187
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rtl818x/rtl8187/rtl8187.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/ath9k
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/ath9k/ath9k_htc.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/ath9k/ath9k_hw.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/ath9k/ath9k_common.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/carl9170
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/carl9170/carl9170.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/ath/ath.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/zd1211rw
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/zd1211rw/zd1211rw.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt73usb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt2x00usb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt2800lib.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt2800usb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt2500usb.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/rt2x00/rt2x00lib.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/wireless/8192cu.ko
/lib/modules/3.14.28-1.12/kernel/drivers/net/tun.ko
/lib/modules/3.14.28-1.12/kernel/drivers/usb
/lib/modules/3.14.28-1.12/kernel/drivers/usb/class
/lib/modules/3.14.28-1.12/kernel/drivers/usb/class/cdc-acm.ko
/lib/modules/3.14.28-1.12/extra
/lib/modules/3.14.28-1.12/extra/bcm_event.ko
/lib/modules/3.14.28-1.12/extra/procmk.ko
/lib/modules/3.14.28-1.12/extra/dvb_base.ko
/lib/modules/3.14.28-1.12/extra/dvb-bcm7252s.ko
/lib/modules/3.14.28-1.12/extra/fpga_directc.ko
/lib/modules/3.14.28-1.12/extra/cdfs.ko
/lib/modules/3.14.28-1.12/extra/brcmfb.ko
/lib/modules/3.14.28-1.12/modules.dep
/lib/modules/3.14.28-1.12/modules.softdep
/lib/modules/3.14.28-1.12/modules.builtin.bin
/lib/modules/3.14.28-1.12/modules.dep.bin
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter0/video3
/dev/dvb/adapter0/video2
/dev/dvb/adapter0/audio3
/dev/dvb/adapter0/audio2
/dev/dvb/adapter0/audio1
/dev/dvb/adapter0/ca12
/dev/dvb/adapter0/ca11
/dev/dvb/adapter0/ca10
/dev/dvb/adapter0/ca9
/dev/dvb/adapter0/ca8
/dev/dvb/adapter0/ca7
/dev/dvb/adapter0/ca6
/dev/dvb/adapter0/ca5
/dev/dvb/adapter0/ca4
/dev/dvb/adapter0/ca3
/dev/dvb/adapter0/ca2
/dev/dvb/adapter0/ca0
/dev/dvb/adapter0/frontend7
/dev/dvb/adapter0/frontend6
/dev/dvb/adapter0/dvr12
/dev/dvb/adapter0/dvr11
/dev/dvb/adapter0/frontend5
/dev/dvb/adapter0/dvr10
/dev/dvb/adapter0/frontend4
/dev/dvb/adapter0/frontend3
/dev/dvb/adapter0/dvr9
/dev/dvb/adapter0/frontend2
/dev/dvb/adapter0/dvr8
/dev/dvb/adapter0/frontend1
/dev/dvb/adapter0/dvr7
/dev/dvb/adapter0/frontend0
/dev/dvb/adapter0/dvr6
/dev/dvb/adapter0/audio0
/dev/dvb/adapter0/dvr5
/dev/dvb/adapter0/dvr4
/dev/dvb/adapter0/video1
/dev/dvb/adapter0/dvr3
/dev/dvb/adapter0/video0
/dev/dvb/adapter0/net12
/dev/dvb/adapter0/dvr2
/dev/dvb/adapter0/demux12
/dev/dvb/adapter0/net11
/dev/dvb/adapter0/demux11
/dev/dvb/adapter0/net10
/dev/dvb/adapter0/demux10
/dev/dvb/adapter0/net9
/dev/dvb/adapter0/demux9
/dev/dvb/adapter0/net8
/dev/dvb/adapter0/demux8
/dev/dvb/adapter0/net7
/dev/dvb/adapter0/demux7
/dev/dvb/adapter0/net6
/dev/dvb/adapter0/demux6
/dev/dvb/adapter0/net5
/dev/dvb/adapter0/demux5
/dev/dvb/adapter0/net4
/dev/dvb/adapter0/demux4
/dev/dvb/adapter0/dvr0
/dev/dvb/adapter0/net3
/dev/dvb/adapter0/demux3
/dev/dvb/adapter0/net2
/dev/dvb/adapter0/demux2
/dev/dvb/adapter0/net0
/dev/dvb/adapter0/demux0
/dev/dvb/adapter1
USBTuner revision
DVB Drivers revision
Vu+ Kernel Drivers
-rw-r--r-- 1 root root 8116 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/bcm_event.ko
-rw-r--r-- 1 root root 5992 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/brcmfb.ko
-rw-r--r-- 1 root root 29952 Aug 14 20:52 /lib/modules/3.14.28-1.12/extra/cdfs.ko
-rw-r--r-- 1 root root 776844 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/dvb-bcm7252s.ko
-rw-r--r-- 1 root root 6650760 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/dvb_base.ko
-rw-r--r-- 1 root root 2804 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/fpga_directc.ko
-rw-r--r-- 1 root root 4904 Aug 14 20:50 /lib/modules/3.14.28-1.12/extra/procmk.ko
Because it really is not happening, now in my vusolose v2 until the tuner disappears, let me pass just like in vu + uno4k.
Something is running with the driver or firm that is not compatible with usb tdt.
I put a screenshot.
They do not work at the beginning in a restart it started to work and now in another restart there is no way to make it work
Box Info
BH Ver:
USB devices
Kernel Messages
[ 18.338974]
NIM Sockets
NIM Socket 0:
Type: DVB-S2
Frontend_Device: 0
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
NIM Socket 2:
Type: DVB-S2
Frontend_Device: 2
NIM Socket 3:
Type: DVB-S2
Frontend_Device: 3
NIM Socket 4:
Type: DVB-S2
Frontend_Device: 4
NIM Socket 5:
Type: DVB-S2
Frontend_Device: 5
NIM Socket 6:
Type: DVB-S2
Frontend_Device: 6
NIM Socket 7:
Type: DVB-S2
Frontend_Device: 7
Modules Loaded
Module Size Used by
bluetooth 309479 4
brcmfb 1483 3
r8188eu 584112 0
Kernel Objects
DVB devices
/dev/dvb
/dev/dvb/adapter0
/dev/dvb/adapter1
USBTuner revision
Vu+ Kernel Drivers
Aqui mas datos.
Well the problem after doing more than a thousand tests is that when doing a reboot many times the tuner may stop, which I no longer know if it is a driver problem or that, but that there are times that it works and another one that the tuner disappears usb tdt.
Well I continue with the same problem and from what I see is that before the driver was AF9015 1.0 - R6 and now the one you have in your drivers is the AF9015 1.0 - R0 version and that is why the usb tdt does not work.
Is there a way to also put revision R0 ?.
