NRK 0.8 Thor - channels weak or bad signal
cenobite
Is it just me or do VU+ series have some issues with the NRK channels on Thor 0.8 ? I have just changed back to VU+ solo2 from DB800HD because the DB is veeeery slow and also very old. At the moment I have a 55cm wavefrontier antenna with 4 lnb's. All configured and setup with SatLink satfinder. Using common interface with Conax camd and CD card. All channels except from NRK works smooth in HD quality. My signal rate is aprox. 75% but the picture breaks up in pixels and the sound is crap. I also had a VU+ DUO once before the DB800 with the same issue. But what I can remember is the VU+ DUO didn't have this problem before an upgrade of some kind ?? Am I into something here ? If I change back to DB800 again, the NRK channels works excellent.. Could it be the Camd module, because I use ***** in my DB800 ?
- cheers !
- cheers !
Warning to read the rules of the forum
discussion about cams/emulators is not allowed.
What cams / emulators ? I am paying for my subscription. I paid Canal Digital for my Conax Camd. I have a Canal Digital subscription.
How Am I gonna explain this in other words ? CD card = Canal Digital (paid subscription).
I am just wondering why Norwegian NRK (wich is included in my Canal Digital package) is only pixels and crappy sound.
You MUST read our board rules as @Matrix10 said (rule n.4) because WE DON'T TOLERATE usage, support or anything else regarding emulators.
On your previous post you talked about a famouse emulator, so the reason for post by @Matrix10 .
I haven't a Conax card so I cannot check if that cryptosystem has been included with Solo2 box out-of-the-box from Vu+.
If you are using your subscription with a CI modules it's OK: remember our rules in the future.
OK, sorry for the mistake. Won't happen again.
The story is that I have paid Canal Digital subscription in Norway, using a Conax CA module or camd in common interface. It seems like the tuner have some issues with the HD channels. C more and NRK. The picture starts to break up in pixles and the sound is far from good. C more wont even give me a picture with 82% signal rate ?!? My antenna setup is mentioned in my first post. If I switch back to my old DB 800HD tuner, it all works well.. When trying sat.finder in the menu on NRK it shows 99% signal and AGC at 73% and ofc. BER = 0
Also Nat.Geo HD runs well at 71% sign.quality
Could this may relate to my old CI module. It says Conax Rev 1.0 P/N:901647 on the module. It is from late -90 or early 2k. Anyone that can confirm this ?
I can't check your channels, but for my Tivusat ones in HD I had to change the settings in the C.I. menu particularly this
High bitrate support--> YES
So, do some tries with it and probably the next parameter I can't remeber now and whom name I can't check these days because I'm not at home.
