O.Multiboot does not work
ertan3
O.Multiboot works fine in OBH version 4.4.013. When I upgrade the image to the latest version, O.Multiboot does not work
This kind of generic message don't help anyone: neither us who would like to answer, nor other user who (in case) have a similar issue.
"O.Multiboot does not work" does not mean anything (for me, and I bet for thousand users, it works!)
Please explain in a detailed way what you did, what does not work.
Bu tür genel mesajlar hiç kimseye yardımcı olmaz: ne yanıtlamak isteyen bize ne de (durumda) benzer bir sorunu olan diğer kullanıcılara.
"O.Multiboot çalışmıyor" hiçbir şey ifade etmiyor (benim için ve bahse girerim bin kullanıcı için işe yarıyor!)
Lütfen ne yaptığınızı, neyin işe yaramadığını ayrıntılı bir şekilde açıklayın.
Clicking on openmultiboot restarts GUI with "software problem" message
It's (obviously) only your case, as nobody else have reported the same issue, so far. You must've installed some crap plugin or your update process was interrupted. If you have a previous backup, you may get back and then update again.
Otherwise, you need to reflash.
I downloaded OBH 4.4.013 from your site and installed it on my vusolo2 device. O.Multiboot is working. I updated to the latest version 4.4.018 without installing any plugins. I clicked O.Multiboot and restarted the GUI with the message "software problem".
Then, maybe the problem is in the device where the OMB is installed: where did you install it? If it's a USB stick, just try another one. This is only a theory, of course.
OK: so don't try any workaround. If you are so sure, we are also sure there is no problem. And, above all, you haven't attached any crash log.
No need to justify: no crashlog, no party...
Without a crashlog, and considering we have just two users claiming possible issues among maybe hundreds? thousands? all this thread is useless.
