OBH 1.0 avvio lento
  • Thread starter Thread starter rinoronie
  • Start date Start date
R
rinoronie
Guest
Ho ripristinato un backup da un solo2 ad un altro, ma l'avvio da quest'ultimo é molto lento, cosa posso controllare?
cat /var/volatile/log/dmesg
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Linux video capture interface: v2.00
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.17
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource wktmr
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
fuse init (API version 7.22)
msgmni has been set to 1117
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10406900 (irq = 65, base_baud = 5062500) is a 16550A
console [ttyS0] enabled
bootconsole [early0] disabled
serial8250.0: ttyS1 at MMIO 0x10406940 (irq = 66, base_baud = 5062500) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10406980 (irq = 67, base_baud = 5062500) is a 16550A
loop: module loaded
ahci strict-ahci.0: can't get clock
__clk_enable: sata [1]
bcm40nm_pm_sata_enable 00
ahci strict-ahci.0: SSS flag set, parallel bus scan disabled
ahci strict-ahci.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl platform mode
ahci strict-ahci.0: flags: ncq sntf stag clo slum part
scsi0 : ahci_platform
scsi1 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x100 irq 41
ata2: SATA max UDMA/133 mmio [mem 0x10181000-0x10190fff] port 0x180 irq 41
brcmstb_nand: NAND controller driver is loaded
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
Found PHY at Address 3
bcmgenet: configuring instance #0 for external RGMII
__clk_disable: enet [0]
bcm40nm_pm_genet_disable 00
__clk_disable: network [0]
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ata1: SATA link down (SStatus 0 SControl 300)
__clk_enable: usb [1]
bcm40nm_pm_usb_enable 00
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 69, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 70, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-brcm ehci-brcm.2: Broadcom STB EHCI
ehci-brcm ehci-brcm.2: new USB bus registered, assigned bus number 3
ehci-brcm ehci-brcm.2: irq 74, io mem 0x10490300
ehci-brcm ehci-brcm.2: USB 0.0 started, EHCI 1.00
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ehci-brcm ehci-brcm.3: Broadcom STB EHCI
ehci-brcm ehci-brcm.3: new USB bus registered, assigned bus number 4
ehci-brcm ehci-brcm.3: irq 75, io mem 0x10490500
ehci-brcm ehci-brcm.3: USB 0.0 started, EHCI 1.00
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 5
ohci-brcm ohci-brcm.0: irq 71, io mem 0x10480400
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 6
ohci-brcm ohci-brcm.1: irq 72, io mem 0x10480600
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.00: ATA-8: ST1000LM024 HN-M101MBB, 2AR10002, max UDMA/133
ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 1 port detected
ohci-brcm ohci-brcm.2: Broadcom STB OHCI
ohci-brcm ohci-brcm.2: new USB bus registered, assigned bus number 7
ohci-brcm ohci-brcm.2: irq 76, io mem 0x10490400
ata2.00: configured for UDMA/133
scsi 1:0:0:0: Direct-Access ATA ST1000LM024 HN-M 2AR1 PQ: 0 ANSI: 5
sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 1:0:0:0: [sda] 4096-byte physical blocks
sd 1:0:0:0: Attached scsi generic sg0 type 0
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 1 port detected
ohci-brcm ohci-brcm.3: Broadcom STB OHCI
ohci-brcm ohci-brcm.3: new USB bus registered, assigned bus number 8
ohci-brcm ohci-brcm.3: irq 77, io mem 0x10490600
usb 2-1: new high-speed USB device number 2 using ehci-brcm
hub 8-0:1.0: USB hub found
hub 8-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
usbcore: registered new interface driver btusb
Bluetooth: Generic Bluetooth SDIO driver ver 0.1
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
PM: CP0 COUNT/COMPARE frequency does not depend on divisor
EBI CS0: setting up NAND flash (primary)
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
NAND device: 256MiB, SLC, page size: 2048, OOB size: 64
brcmnand brcmnand.0: 256MiB total, 128KiB blocks, 2KiB pages, 16B OOB, 8-bit, Hamming ECC
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000003b20000
nand_read_bbt: bad block at 0x000005c00000
Creating 4 MTD partitions on "brcmnand.0":
0x000001f00000-0x000010000000 : "rootfs"
0x000001f00000-0x000010000000 : "rootfs(redundant)"
0x000000200000-0x000000900000 : "kernel"
0x000000900000-0x000000a00000 : "mac"
UBI: attaching mtd0 to ubi0
sda: sda1
sd 1:0:0:0: [sda] Attached SCSI disk
random: nonblocking pool is initialized
UBI: scanning is finished
UBI: attached mtd0 (name "rootfs", size 225 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1794, bad PEBs: 6, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 512/60, WL threshold: 4096, image sequence number: 965308247
UBI: available PEBs: 0, total reserved PEBs: 1794, PEBs reserved for bad PEB handling: 34
UBI: background thread "ubi_bgt0d" started, PID 53
ALSA device list:
No soundcards found.
UBIFS: parse sync
UBIFS: background thread "ubifs_bgt0_0" started, PID 56
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 221573120 bytes (211 MiB, 1745 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID 2CA38E38-2A6A-4601-86F8-EB6A9E9156AB, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:12.
devtmpfs: mounted
Freeing unused kernel memory: 248K (807f2000 - 80830000)
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
SGI XFS with security attributes, realtime, large block/inode numbers, no debug enabled
usb 2-1: dvb_usb_af9035: prechip_version=00 chip_version=03 chip_type=3802
usb 2-1: dvb_usb_v2: found a 'AVerMedia HD Volar (A867)' in cold state
usb 2-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-af9035-02.fw'
usb 2-1: dvb_usb_af9035: firmware version=12.5.13.0
usb 2-1: dvb_usb_v2: found a 'AVerMedia HD Volar (A867)' in warm state
usb 2-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (AVerMedia HD Volar (A867))
i2c i2c-0: af9033: firmware version: LINK=12.5.13.0 OFDM=6.8.13.0
usb 2-1: DVB: registering adapter 1 frontend 0 (Afatech AF9033 (DVB-T))...
mxl5007t 0-0060: creating new instance
Registered IR keymap rc-empty
input: AVerMedia HD Volar (A867) as /devices/platform/ehci-brcm.1/usb2/2-1/rc/rc0/input0
rc0: AVerMedia HD Volar (A867) as /devices/platform/ehci-brcm.1/usb2/2-1/rc/rc0
usb 2-1: dvb_usb_v2: schedule remote query interval to 500 msecs
usb 2-1: dvb_usb_v2: 'AVerMedia HD Volar (A867)' successfully initialized and connected
usbcore: registered new interface driver dvb_usb_af9035
