On my Vu+ Solo 4K using Blackhole 3.0.9L (BH) I installed Open Multiboot (OMB) and put Open Blackhole (OBH) 4.3.0.27 on a 2 partition 16Gb USB stick.
BH works well and has no problems at all. Especially, Internet and LAN work well.
When I run OBH I can watch TV channels as normal but I cannot get access to my LAN network.
- Every time I go to configure the LAN, the option “user interface” is on NO. Every time I have to change that to YES. Using DHCP or not, when I do a network test I get “network disconnected”; “IP address unconfirmed”; “Name server unconfirmed”.
- When I do “scan wireless networks” the VU+ crashes. A reference to python 2.7 is shown on screen in about 10 lines of errors.
- I have tried the network wizard as well with rthe same results.
Back in BH is notice that all my EPG data is no longer showing and I have to re scan to get it back.
The USB is formatted in ext4 by BH with 2 partitions. I thought my BH EPG would be on partition 1 and OBH on partion 2.
Questions:
1. Can OBH run in OMB with BH in flash?
2. Network is easily connected to in BH. When running OBH from the USB, the network is not available. Is this normal?
3. I have 2 partitions mounted on the USB stick, sdb1 and sdb2. When I configure EPG (in BH) I can only choose media/usb and cannot specify sdb1 or sbd2. Using File browser: USB Stick shows me crossepg, lost+found, open-multiboot, open-multiboot-upload, epg.dat.loading. So how do I get my EPG on (say) sdb1 and OMB on sdb,2?
Thanks in advance for any suggestions.
Questions:
