OBH full backup crashes changing its settings
AlexWilMac
Moderator
Unfortunately, this very important system component has often issues.
This time, for instance, I wanted to simply change the time of the daily backup. But, as soon as I press GREEN to save the new time, I get the crash.
I opened the file setting in /etc/enigma2 to try and change directly there this time and I found the line
config.imagemanager.scheduletime=8:6
(as I have it set at 8:06am) and I tried and change it to
config.imagemanager.scheduletime=2:6
and restart the GUI, but the value shown by the GUI, after the restart, didn't change: it stayed at 8:06.
I attach the crashlog.
Download the same skin " EclipseFHD" from the feeds and retry!
Before downloading again, to be sure I also deleted the skin's folder but nothing changed. Actually: it changed the screen because, after the last OBH update, it wasn't the traditional one.
But the result was the same.
Also, the strange is that the crash occurs even before pressing GREEN. Whilst editing the start time it usually crashes.
So I decided to go back (downloading it again, to be sure) to my favourite skin, EclipseFire, but same result. This time I was at least able to edit the start time but the crash occurred after pressing Green.
Then I tried the default skin, BlackShadowSE: same crash.
But the main question is: why I don't manage to change the settings file in /etc/enigma2?
How is it possible that it gets back to the old time after the restart? I checked it, after the manual editing, and the new time was there. Then I rebooted and... nothing. I also sent it during the reboot, in case it behaves like timers.xml (although, I've never had troubles in editing it in real time in the past). Nothing.
This is what really puzzles me: how is it possible it seems to change it back to the previous status?
Can you please check it, using the default skin?
Enviado do meu iPhone usando o Tapatalk
By default skin you mean the "Emergency" one? As of attachment? It was the same: crash after pressing Green (I attach also the crashlog).
If by Default Skin you mean BlackShadowSE, I had already tried it, as said in post#3.
But, again: why my editing of the file settings is mysteriously replaced by one with the old time?!? Where does it pick it up?!?
Is there another copy of this file in another folder different from /etc/enigma2?
Should be fixed on the next update ... Open BlackHole 4.4.014 ;)
Note: Default skin is the default OBH ( MX BlackShadow SE_P )
OK, good!
Yes, I meant BlackShadow SE P, even because now there isn't any BlackShadow skin in the feed. Before, we had both BlackShadowSE and BlackShadowSE_P. But now this last is the default. ;)
