OBH skin updates ...
Gold_66
Just saw that my beloved Maestra 2C is also there. :)
Now, the question is: Will I lose my customised infobar if I update to 4.1.015?
And if so, will it be sufficient to just replace <screen name="SecondInfoBar" part later to get it back?
Well, I didn't. :D
But I probably would, if I tried to re-download it from feed and overwrite the existing one.
Anyway, this thread can be deleted - I don't think it will be of some use to anyone. :cool:
But you have no button names in Timer list/ edit
and you have no full transponder info in Channel list ? :chair:
So you can update and replace <screen name="SecondInfoBar"
:lamo:
Yep, just saw that buton names are missing in Timer List, but I never use timers anyway. :p
As for transponder info in Channel List, I have my hand-made one since long ago. :D
Thanks all the same for info, and for your hard work with all these beauties! :notworthy:
Thank you Matrix10 for your skins. I've updated to the latest release the EclipseFHD which is the one I prefer. There is a doubt I have. If, when downloading from the server, you ask for a preview you get an image in which only two blue dots appear (one on each side) of the elapsed time in the info bar. After updating, in the info bar you have the usual four (two each side). Am I missing something? By the way, I've never seen one changing colour when an update is available (as per a recent thread).
Best regards.
Best regards.
This is a screen shot from the Black Hole image with two blue dots.
Open Black hole should show update.
I'll check the next time update.
I installed a skin via online update on Vu Solo 2 with Open BlackHole 4.1.001 on hard drive and Open BlackHole 4.1.022 in the flash. Now the receiver is stuck on starting. My mistake as the skins were meant for 4.1.022 and above. Any solution?
Well I installed a smaller original Open BlackHole Image and deleted the Image on HDD from open-multiboot via dcc and reflashed the back up of Open BlackHole 4.1.022. Thankfully everything is working fine again. Earlier I was not getting access to the Vu Solo 2 as it was stuck at boot. I think it may have been a flash overload. Thanks for your quick response. Regards
Update all skins for Open Black Hole
Download from OBH image server
added network speed info (receive and transmit) to the second infobar.
You can use network speed info for IPTV, Transcoding,Tuner fallback etc.
(Deafult skin update follows in the next image update.)
I started the skin updates for OBH 4.4 UP
MX Slim Line NP OpenBH (4.4 / up)
MX Slim Line OpenBH (4.4 / up)
MX Slim Line Blue OpenBH (4.4 / up)
BlackShadow SE OpenBH (4.4 / up)
Eclipse SE OpenBH (4.4 / up)
Eclipse FHD OpenBH (4.4 / up)
Eclipse Fire OpenBH (4.4 / up)
BlackShadow SEP default skin OpenBH (4.4 / up)
MX Sline Grey OpenBH (4.4 / up)
MX Sline Blue OpenBH (4.4 / up)
MX Sline Black OpenBH (4.4 / up)
Skin updates for OBH 4.4 UP
MX Maestra Firebrick OpenBH (4.4 / up)
MX Maestra Blue OpenBH (4.4 / up)
MX Maestra Gray OpenBH (4.4 / up)
MX Maestra Black Weather OpenBH (4.4 / up)
MX Maestra2 Black OpenBH (4.4 / up)
MX Maestra SE3 OpenBH (4.4 / up)
MX Maestra SE2 OpenBH (4.4 / up)
MX Maestra SE1 OpenBH (4.4 / up)
MX Maestra Black OpenBH (4.4 / up)
MX Maestra2 OpenBH (4.4 / up)
MX Maestra2b Weather OpenBH (4.4 / up)
MX Maestra2 Weather OpenBH (4.4 / up)
MX Maestra2 C OpenBH (4.4 / up)
MX Maestra2 Black Weather OpenBH (4.4 / up)
MX BlackSea I OpenBH (4.4 / up)
MX Blue Sea OpenBH (4.4 / up)
MX Red Sea I OpenBH (4.4 / up)
MX Black Sea OpenBH (4.4 / up)
MX Red Sea OpenBH (4.4 / up)
MX DarkBlue Sea OpenBH (4.4 / up)
MX Sline DarkBlueSea OpenBH (4.4 / up)
Waves 4 Weather OpenBH (4.4 / up)
Waves 4 Fire Weather OpenBH (4.4 / up)
Waves 4 Fire OpenBH (4.4 / up)
Waves 4 OpenBH (4.4 / up)
Waves 3 OpenBH (4.4 / up)
Waves 2 OpenBH (4.4 / up)
Waves 1 OpenBH (4.4 / up)
Waves 5 OpenBH (4.4 / up)
MX Titanium OpenBH (4.4 / up)
MX SilverLight P OpenBH (4.4 / up)
MX HQ9W OpenBH (4.4 / up)
MX HQ10 OpenBH (4.4 / up)
MX Graphite XE OpenBH (4.4 / up)
MX Graphite SE P OpenBH (4.4 / up)
MX Graphite SE OpenBH (4.4 / up)
MX Graphite HQ P OpenBH (4.4 / up)
MX HQ7 OpenBH (4.4 / up)
