Last week, I bought a Vu+ Zero 4K DVB-T / C. I installed OBH image on it. The installation ran smoothly. However, Scanning DVB-C channels doesn’t return and channel. I installed BH and there, I could retrieve the channels. Any guess?
Hi Mick
Thank you
I do not have the provider neither on BH nor on OBH. I use frequency steps method for both of them. With BH, I can find them but not with OBH. I'll have a second look at it
Try the attached one: is taken from my OBH. Unzip it and put in
/etc/tuxbox/
and restart the GUI.
I don't have cable services but it's the original from OBH (4.3.023, of course): don't tell me you don't have 4.3!
You should be able to copy the cables.xml file from Black Hole, onto your desktop, by right clicking, on the file, then send it to your Open Black Hole folder, overwriting the other cables.xml file, using Filezilla.
