Odd behaviour with PiP with 4.1.033, not with .032
AlexWilMac
Moderator
With Solo4K something very odd happens with PiP: however I activate it of the two possible ways, I can't put in PiP one of the channels in my first bouquet. To be precise, the #11 does not want to be put in PiP and, instead, I have the #3 there.
I tried also by PiP-Zap: every other channels work perfectly but, when I arrive by zapping forward to the #11... it puts the #3! The same, choosing 11 by the remote with PiP-Zap active.
I checked some of my backups (I have scheduled them daily): two days ago, before the last update of .033, it was the same. Using the last update of a .032, instead, the bug it's not present, even reloading there my bouquets as they are today.
I haven't had the chance of checking the same situation on a Duo2 currently at my parents'.
Surely, is one of the oddest bugs I have ever encountered.
It seems that PiP has something against me, because is also still present (only in Solo4K, not in Duo2) the bug about the BIG PiP feature that hasn't been solved yet (and it puts the "big" PIP in the top-left quarter of the screen.
Update: it does not depend on the position in the bouquet but it's related only to that channel. I'll try a complete scan, deleting the previous settings to check if there is some issue about some S_Ref.
Another try seems to show that the odd behaviour does not depend on the settings but it depends only on the image because I loaded into last 0.33 old settings from April and the channel with Sref
1_0_19_36E4_6A4_13E_820000_0_0_0
cannot be played in PiP and, at its place, it plays in PiP this other channel from 13°E
1_0_1_D4B_1450_13E_820000_0_0_0
Instead, if I load a backup old enough (.032 or older) everything works fine.
I also rescanned the whole 13°E without success.
Just the last update about this really odd behaviour: I'm now completely sure that it's not a "settings" issue (including satellites.xml, lamedb and the like... because I've done all the 4 possible tries to understand if it depended on the OBH version or on the settings.
1&2) OBH 4.1.032 + current or old settings, NO PROBLEM
3&4) OBH 4.1.033 + current or old settings, does not work
So, even if it seems strange, I can't have in PiP 1_0_19_36E4_6A4_13E_820000_0_0_0 (RSI La2) because the image put there Rai3 HD.
And there is also another PiP issue, now (with any channels, not only the one above): after doing some zapping when PiP is enabled, after some of them you have NO AUDIO. You have to exit PiP and then zap to any channel to have the audio working again.
Just an update: at least this problem was solved. Despite the fact I had restored old settings without success, it was indeed a problem in some file related to the channels, probably lamedb or some else. I thought that using the OpenWebInterface's bouquet editor or, in my case, iDreamX, they would restore also all the files related to settings but, clearly, it is not so because a clean install solved the problem.
