oe 2.0.0 d-link dwa 125 usb wifi problem
hakki
ı am useing d-link dwa 125 usb wifi stick it didn,t work in oe 2 no problem in bh 1.79 image and before ip and DHCP problem
H/W ver:A2 F/W: 1.30
Should be supported ... I've the HW A2 FW 1.40 and works very well.
If you have Windows avaiable, please post here the USB IDs of your device:
1. Goto into Devices Manager
2. Right click with mouse on your device and select Property
3. Goto into "Details" tab
4. Select from drop down menu "Hardware ID" and post here all the strings you see (you can do copy&pase)
If you have Linux:
lsusb
if this problem can not be solved
I want to buy new one what is your advise about usb wifi stick
for bh oe 2.0.1 now and then
