skinnydipper
Ok here's my boring story
Had a vu+solo2 for just over a year now, has been working fine, just renewed a sub etc.....
Then strange thing happened, found that I would get a tuner fail problem every so often. Read through everything on forums, checked signal etc, basically im sure signal is good, put in back of TV which has freesat and works fine, went through all preferences and all set up correctly,
So I was running a older version of openvix apollo so thought Id reflash it, however the tuner worked on certain backups but not all.
So I decided Id try and do a download and clean install. Dowmloaded latest openvix
Now next problem in equation is I've only got macs no pc's. so tried initialising usb stick in vuplus and then ftp'ing files onto usb stick.
This didnt work.
For the ftp'ing I use idreamx software which has been really good.
But the solo2 just would not boot from usb stick, tried it from little toshiba hard drive again would not boot
started going nuts
went round a friends house, all pc's , downloaded files, reformated drives , extracted files to drives. Tried to reboot but still no
then out of frustration, looked at all files on idream x on the vu+ and DELETED THEM ALL, thinking I could boot from USB - No joy VU+ just says starting
what do I do now???
thanks for any response
This didnt work.
started going nuts
what do I do now???
