Open Air plugin
Stig-O
BH Lover
I have tryed to install Open Air plugin 0.5.4 and 0.5.6, but anyone of those comes up in the meny.
Are i'm doing something wrong? Using BH 1.7.8
It won't show up in the menu but it should show up in your plugin list.
Press the green button on your remote to check
Another thing, just read Matrix's response to someone else on this forum
If it's not showing your plugin list in the Menu >
Your Plugins disappear because you have put in
System Menu >>Customize to Setup Mode ...Simple
If you put in Customize Panel setup mode to Expert and SAVE
Restart image you will have all options and Plugins Menu
