Open BH 1.0 Vu+Duo2 - Nuove implementazioni
hall9000
Complimenti al gruppo per la nuova immagine.
Volevo se possibile delle delucidazioni , sull'uso di queste nuove feautures....
  • Fallback - Fallback tuner settings moved to Service searching menu into its own menu
  • Fallback - Remote bouquets copier (Channel Importer). For receivers used as clients, copies and loads the channel list from the server box.
  • Fallback - ability for client to not write EPG data back to server box. Means epg.dat can be shared over a network mount without fear of corruption.
Volevo inoltre sapere se su questa versione è possibile usare i tasti stop e pausa nella visione dei VOD.
Hall
If you have a client / partner box
Enable Fallback in Fallback configuration client box.
Write IP address of the main box (server) example >> http://192.168.192.1:8001
and Save.
In the client box you have to upload the same channel list as in the main box.
You can use dreamboxedit to upload settings or to read settings from main box and upload to client box.
You can also use plugin Channels importer .To import channels from main server box to remote box client.
This plugin you can find and install (client box) from plugins>>Download plugins>>systemplugins
after install reboot box.
I have tested with uno 4K (client) and solo 4k main server box.
I have upload the same channels with dreamboxedit in to both boxes.
On the server box you doe not need to configure anything.
On both boxes you have to use OBH 1.0
