open BH lose audio when using openwebif
cargen
hi,
i am experiencing a problem with open BH.
if i watch a program with VLC via open webif at some point i lose the audio.
the issue seems to be triggered when i have network/wifi issue.
if for some reason my wifi signal is weak and the program stops.
when it come back i don't have audio anymore.
to resume the audio, i need to click stop and play again.
hi,
This is dued to your wifi ( weak bandwith ), connect it via lan and test!
i never had this problem with blackhole.
and why after it resume i should lose only the audio?
i don't think it is due to my wifi.
would you know how i can troubleshoot the issue?
is there any log where i can look at?
Are you able to stream HD services?
