Open Black Hole start-up process which are not required for all.
rmg_hrr
Hi,
During start-up many process are automatically started.
example: OpenVpn.
I disabled it and now it don't start during start-up
Would like to know all such optional process which can be turned down safely at start-up so boot time can be reduced.
Thanks in advance.
Uninstall the plugins or system extensions that you don't need.
Anyway be careful with the system extensions...
What do you mean exactly?
The plugins you need to keep depend on what you actually want to do with your receiver...
Please name one or two, plugin extensions I kept minimum.
I do not recommend to delete plugins that are part of image
other than those contained in plugins >> Remove plugins
Start of most of plugins can be turned off / disabled
in the setup of these plugins.
