Open Black Hole Vu+ Zero 0.1
lorenzo64
Open Black Hole 0.1
Main Features:
  • Full Hd skin (1920x1080)
  • HbbTv
  • Open GLes animations (Duo2, Solo2, SoloSE)
  • Xbmc (Duo2, Solo2, SoloSE)
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • Compatible with Pli plugins and Skins
What is Open Black Hole ?
It is an exciting new project from the same team that produce the Black Hole images.
This new project is based on the PLi git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all PLi plugins, feeds and skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the standard Black Hole images, we have also added the Black Hole addons panel and included Full HD skin support, OpenGLes Animations and of course included Xbmc .
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any Open Black Hole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new Open Black Hole image ?
No you don't have to upgrade to the new Open Black Hole image, this image is completely separate from the original Black Hole image, this is simply a new image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new Open Black Hole image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new Open Black Hole image is an additional project and we are fully committed to all images.
Where can I find the Open Black Hole git ?
The Open Black Hole git is located here: http://git.vuplus-community.net
DISCLAIMER
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BLACK HOLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
BH image for me is more attractive, and with a more elegant design!
Besides BH images responds more to my needs for using my ZERO!
Both images are good, depending on the use with + an - .
Test both images longer and choose.
I install vu solose xbcm image İn meoboot , image very nice working but not support xbcm , maybe support coming ?
Sent from my iPhone 6
I 'd make backup and it work now rss slider on chanalle selection bar and now event - next event it support haling valing but how ı do orientaly slider for skin
where to get the skin ?
2-jpg.20558
The default skin has no information about encoding. Thank's
