Open Blackhole 1.0 signal problem
Bucket
Hi!
i have used Blackhole for 3-4 years now and now i got the brilliant idea to upgrade to OBH.
But i cant find any channels on 0.8w and 4.8e
Before the imageupdate everything worked fine, and i have configerd my tuner on my solo 2
Cabel into tuner B Both sats. Tuner A loop through.
Updated sat.xml with my 2 sats only.
But no signal on 0.8 and signal but no channels on 4.8e
What an i doing wrong.
Thank you kindly for any help.
Regards: Bucket
Open Blackhole isn't an upgrade but a slightly different image, with some updated features.
From your posting I'm guessing you either have two dishes, or one dish, and two LNB's, for 4.8E and 0.8W.
Can you please post which model VU+ receiver you have?
There should have been no need to alter your satellites.xml file, as both satellites should have been included, although SES 5, Astra 4A, are problably now listed as 4.9E.
I assume you're using a Diseqc switch, to combine both LNB's to one cable?
Your setup is quite simple so all you need to do is set the Tuner up to Configuration Mode = Simple, Mode = Diseqc A/B and set Port A to Thor 0.8W, or 4.8E, depending on how you've connected your Diseqc switch and Port B to the other satellite.
Can you please post how you've configured your Tuner settings, and more details regarding your satellite setup.
Hello Mick12334, and thank you for your time.
I have one dish 2 lnbs one Diseqc switch. One cabel in from the satdish.
Ihave the cabel connected to Tuner B in my Vu+ Solo2
Tuner a i have as LoopThrough.
Tuner A i have Diseq A/B 4,8e A And 0,8W B
Why tuner B and not A ?
This you wrote is not good.
If you connected the antenna to Tuner B
Tuner B have Diseq A/B 4,8e A And 0,8W B
and Tuner A as LoopThrough to Tuner B.
If you connected the antenna to Tuner A
Tuner A have Diseq A/B 4,8e A And 0,8W B
and Tuner B as LoopThrough to Tuner A.
Try both one of both of them must work.
