Hi folks,
1st, many thanx to all people developing this excellent OpenMultiBoot !!
I followed the recent conversation of meo in OpenPLI forum as well, and just as you released it here today , I tested it this afternoon ... I installed 2 images, Plugin said, everything ok, but when I tried to boot any of the 2 images, my Solo² got stuck with black screen ....
- I had a problem with my 8 GB USB stick : manually formatted with 3 partitions : 512MB Fat32, 4GB ext4 for picons, epg, backups, ans the rest about 3.5 GB in ext4 only for Multiboot
- surprisingly the MultiBoot partition was about 20% used, but file creation was not possible ... disk full.
- after an "aha", i checkrd the inodes .... (df -i) , the USB partions had only max. 3000-4000 inodes !!
- I reformatted the partion : mkfs.ext4 -t ext4 -T huge /dev/sdb3, resulting in about 65000 inodes
- now 2 images installed in Multiboot, they booted fine.
- each image uses about 8-10k inodes , but only max 250MB disk space !!
- then I found out that there are new updates as Shiro stated .... but til now I did not have the time to check them, I'll do it later.
@Ev0 : can you please tell me a) the size of your stick with 12 images and b) how you format it and c) how many inodes you have (df -i on that device.) thx in advance.
