open multoboot Probleme vu+ ultimo
yazid02
Hello all,
I wanted to test the plugin by installing openmultiboot another image and since my reboot seen stuck on the boot BH logo.Do I reflash or is there a way to retrieve it ?
Thank you beforehand.
Hello all,
Wich image has you installed in flash?
You can fix it without reflashing the completely image:
You can flash again image for sure .
But you can reapair flash image if image can not boot up after the bad image in Multiboot
1.Format USB stick Fat32
2.copy from image zip file vuplus folder to your USB stick (Image you have use in flash)
3.remove all files from <ultimo> folder except
4.kernel_cfe_auto.bin and the reboot.update files.
5.Connect the USB stick into the front USB
6. Switch box ON
7.Push - button on the box (not on remote control!) when message appears on display.
Update is done when upgrade completed message is shown on the display.
Note: You must do this, regarding the image and STB you are using.
