sunlight786
hi to all
i am having this issue from several months with my brother vu+duo box to achieve epg, i did try install too many images into vu+duo and so far i like the newest all BH 1.6.7 image.
my set up is
single static dish with 3 lnb, 28.2.,19.2e,13e with diseqc switch
2 wires goes into my vu+duo
in open tv epg configuration i did try to mount inter,hdd, and usb also
open tv provider i only select 28.2e as this is my main sat to watch.
when i press down after all this screen turn into radio made but epg installation finish so quickly .and in the end i d,not have any epg more then now&next
it work some time once every month.
i did try format usb, use different usb etc..........did try reboot box
did try to set reboot or restart enigma2 before and after epg download schedule but no joy.
can some please help me out.many thanks
my set up is
