Open webif small problem
chulbul
BH Lover
I can access it and it works only cant access remote.
When I click SHOW FULL REMOTE it does not show it.
While acccesing via same pc the uno works just fine so what can be the problem ?
It was working fine with BH 2.02 after upgrade to 2.03 I have this problem
uninstall and reinstall it again from b.h. software manager
maybe you have deleted or edit any file or your setup is wrong
the only problem is:
where can I get a version of it to reinstall
Chrome. I have tried all browsers.
Anyway I fixed it: I replaced the solo2 openweibif with that of the uno and now the remote shows up.
Something must have been missing during upgrade
