OpenAir 0.5.4
arzaz
I have installed OpenAir, but unfortunately, i can't find it in the green pannel?
How to fix this issue?
Regrads
Can someone tell me where I can download OpenAir which is compatible to BlackHole 1.7.5 Please
I tried to run Airplayer but it does not work if someone can help me it would be much appreciated
Thankyou
Thankyou
have you already checked in the black hole server?
I just downloaded OpenAir on Blackhole 1.7.9-3 on Vu+ Solo2 and when it restarted the GUI it crashed upon restart. Now I'm in a crashing loop of hell - it just restarts all the time then crashes again. Any help or advice anyone could give me regarding this issue would be sincerely appreciated!
Just ftp to ur box then go to usr/lib/enigma2/phyton/plugins/extensions then find open air delete folder then u box starts normally
Thanks but I can't even access the files via FTP - it's crashes and goes offline before I can do anything. I'm just gonna reflash my box to do a fresh reinstall of Blackhole 1.7.9-3.
If u can't access to box best thing is just re flash box with new image
