Hi,
First,big Thanx for great work on this image!I use it on Vuzero and work great but I can't find udpxy in packages.Can you help me to get udopxy for this image?
Hi,
Not tested, although to install it from the feeds, by executing the following commands by using telnet:
opkg install udpxy
reboot
Note: On the thread you have opened the typo of the plugin name is correct, but in your text ( thread ), you are referring the name as " udopxy ", and this one doesn' exist.
