OpenBH 0.6 Vu+ Duo
Ev0
Admin
OpenBH 0.6
1-jpg.27181
Whats New:
  • Completely new image, now much more compact and lightweight than ever before
  • Switched to new Enigma2 base
  • Added BH SpeedUp panel (so you can add or remove some features)
  • Updated to Inadyn-mt
  • Updated OpenMultiboot (now shows image names on front panel display)
  • Updated to Gstreamer 1.9.0 (GIT)
  • Updated to OE3.4 core
  • Updated to Python 2.7.11
Main Features:
  • MX HQ9W Full Hd skin (1920x1080)
  • Kodi and Youtube Tv (for those models that support it)
  • Chromium OS or Opera (for those models that support it)
  • HbbTv (for those models that support it)
  • OpenMultiboot (all Vu+ models supported)
  • OE-A Plugins
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • SpeedUp panel
  • OpenSSL patched for backwards compatibility with some plugins
  • Compatible with OE-A and PLi plugins and Skins
What is OpenBH ?
It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new OpenBH image ?
No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
2-png.27182
3-jpg.27184
4-jpg.27183
5-jpg.27175
6-jpg.27180
7-jpg.27178
8-jpg.27176
9-jpg.27179
10-jpg.27177
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
Hello everyone, can you tell me if this new IMG recognizes the Turbo USB Tuner DTT? with IMG OpenBH the previous 0.1 and 0.4 was not possible, thank you for the work you do soon.
ho iplementato questa immagine ed ho trovato 2 problemi
1 la rete (wlan)è molto piu rapida ma la devo abilitare tutte le volte che faccio reboot
2 la sequenza di tasti della BH che usasvo pe raccedere ai vari canali e/o satelliti qui non funziona e non trovo quella nuova.,
Hi everyone, but there is someone who answers here on this post publication of IMG ... ??? however, it is streamlined and fast turns all right so far ... the only thing I want to ask is that the Menu 'by Remote Control There are some inscriptions and Words in English, you can have even in Italian ... no bet. .. the basic IMG was written so '... right? thanks, see you soon
Good day
can you add hiding and locking channels to open image like the old normal image
also remote button arrangement to be as the old image
Looks very nice!
Unfortunately in my setup (Duo watching on old 4:3 tv and scart with two Avermedia A867 USB DVB-T sticks) it cannot be used.
- Within two minutes it freezes and I have to power cycle to get the box up and running again for max 2 min. Sometimes it looks like the font of the letters want to change but it freezes immediately.
- Switched back to 0.4 installed A867 driver and AS9... driver then it crashes after 10 min. Reboot doen's help. Removed USB sticks and it's running.
- Recordings list very slow and if I delete one entry it goes back to the top of the list. With >100 programs it's (almost) impossible in a normal way to delete some programs in the middle. If it goes back to the top you forget where you where and you have to search through the whole list again.
But the image look very promising!
Chiedo anche per l'Impostazione " Automatic Resolution " se la Attivo ad ogni Cambio canale il Monitor mi fa un Reflash del Video , come va impostata ... centra la Frequenza del TV ...
devo mettere su 50 Hz ... o Multi ? grazie
Due to recent changes in the OE-A git, we recommend you do not online update OBH 0.6, as it is likely to stop your box from booting.
If you wish to update, please make a backup of your image first, and then use the new full flash update files in the 1st post of this thread. You will then be able to online update in future.
Please also remember to make periodic full backups of your image, just incase there are any future issue's, as it is outside of our control what other developers commit to the OE-A git and the build process is automated, therefore we can only fix issues when they arise but we are unable to predict them.
Due to some users, reporting to us, that they have still had issue's with online updates.
We have released new OpenBH 0.6 full flash files today (see 1st post of this thread).
There should be no more issue's with online updating now (we hope).
Please remember to do a full backup, before you try to update, just incase you do have issue's.
DO NOT DO AN ONLINE UPDATE OF OBH UNTIL FURTHER NOTICE.
IF YOU DO, YOUR BOX WILL BE STUCK IN A BOOTLOOP
WE WILL INFORM YOU WHEN IT IS OK TO USE ONLINE UPDATE AGAIN
