OpenBH 0.6 Vu+ Ultimo
Ev0
Admin
OpenBH 0.6
1-jpg.27181
Whats New:
  • Completely new image, now much more compact and lightweight than ever before
  • Switched to new Enigma2 base
  • Added BH SpeedUp panel (so you can add or remove some features)
  • Updated to Inadyn-mt
  • Updated OpenMultiboot (now shows image names on front panel display)
  • Updated to Gstreamer 1.9.0 (GIT)
  • Updated to OE3.4 core
  • Updated to Python 2.7.11
Main Features:
  • MX HQ9W Full Hd skin (1920x1080)
  • Kodi and Youtube Tv (for those models that support it)
  • Chromium OS or Opera (for those models that support it)
  • HbbTv (for those models that support it)
  • OpenMultiboot (all Vu+ models supported)
  • OE-A Plugins
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • SpeedUp panel
  • OpenSSL patched for backwards compatibility with some plugins
  • Compatible with OE-A and PLi plugins and Skins
What is OpenBH ?
It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new OpenBH image ?
No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
2-png.27182
3-jpg.27184
4-jpg.27183
5-jpg.27175
6-jpg.27180
7-jpg.27178
8-jpg.27176
9-jpg.27179
10-jpg.27177
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
Open Black Hole 0.6 skins
which can be downloaded from OBH image server.
(green button>>yellow>>Addons Download Manager>>Open Black Hole Image skins)
OpenBlackHole-Skins MX_HQ7 for Open Black Hole 0.6
OpenBlackHole-Skins MX_S6p for Open Black Hole 0.6
OpenBlackHole-Skins MX_Graphite_HQ_P for Open Black Hole 0.6
OpenBlackHole-Skins MX_HQ9B for Open Black Hole 0.6
OpenBlackHole-Skins MX_HQ10 for Open Black Hole 0.6
Due to recent changes in the OE-A git, we recommend you do not online update OBH 0.6, as it is likely to stop your box from booting.
If you wish to update, please make a backup of your image first, and then use the new full flash update files in the 1st post of this thread. You will then be able to online update in future.
Please also remember to make periodic full backups of your image, just incase there are any future issue's, as it is outside of our control what other developers commit to the OE-A git and the build process is automated, therefore we can only fix issues when they arise but we are unable to predict them.
Due to some users, reporting to us, that they have still had issue's with online updates.
We have released new OpenBH 0.6 full flash files today (see 1st post of this thread).
There should be no more issue's with online updating now (we hope).
Please remember to do a full backup, before you try to update, just incase you do have issue's.
DO NOT DO AN ONLINE UPDATE OF OBH UNTIL FURTHER NOTICE.
IF YOU DO, YOUR BOX WILL BE STUCK IN A BOOTLOOP
WE WILL INFORM YOU WHEN IT IS OK TO USE ONLINE UPDATE AGAIN
