OpenBH 0.6 Vu+ Ultimo4K Pre-Release
Ev0
Admin
Happy New Year 2017 from the Black Hole Team
Now we know that many of you have your shiney new Ultimo4K and Uno4K receivers and wish to use them with OpenBH, however at this time, the images simply are not ready to be fully released, as there are a few bugs that we have not managed to iron out yet.
However the images are stable, therefore as it's New Year, we have a little gift for you and that is the Pre-Release (Beta tester images) for the Ultimo4K and Uno4K.
Please take note, these are Beta images, therefore there are some issue's:
1) Wi-Fi not working (Ultimo4K)
2) Motor only works on FBC DVB-S2 tuner in Slot1 (Ultimo4K)
3) Screenshot / Grab not working (Ultimo4K/Uno4K)
4) Turbo Tuner not working (Ultimo4K)
5) Blindscan not working (Ultimo4K/Uno4K)
Stay tuned... We will update this release post whenever new issues are discovered...
OpenBH 0.6
Whats New:
  • Completely new image, now much more compact and lightweight than ever before
  • Switched to new Enigma2 base
  • Added BH SpeedUp panel (so you can add or remove some features)
  • Updated to Inadyn-mt
  • Updated OpenMultiboot (now shows image names on front panel display)
  • Updated to Gstreamer 1.9.0 (GIT)
  • Updated to OE3.4 core
  • Updated to Python 2.7.11
Main Features:
  • MX HQ9W Full Hd skin (1920x1080)
  • Kodi and Youtube Tv (for those models that support it)
  • Chromium OS or Opera (for those models that support it)
  • HbbTv (for those models that support it)
  • OpenMultiboot (all Vu+ models supported)
  • OE-A Plugins
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • SpeedUp panel
  • OpenSSL patched for backwards compatibility with some plugins
  • Compatible with OE-A and PLi plugins and Skins
What is OpenBH ?
It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new OpenBH image ?
No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
  • openbh-0.6-vuultimo4k-20170302_usb_release_6425a42.zip
Nitemare
Pre-release issue:
Tuner B is only giving option for the USB Tuner ... I need option for second cable of Tuner Motorized Tuner A
so back to BH for now ..
Thanks team for letting us see that OBH image for Ultimo 4K not far away!!! :)
Ev0
Admin
Pre-release issue:
Remove your usb tuner
tom001
thank you very much, i love the look of the open image. The only think i am waiting for is the Fast Channel Change option. This option is great with cable and the ultimo 4K. I am hoping you will upgrade it very soon!
Nitemare
After today's update (06.01.17) to image 0.6.024 I've noticed that my Autoresolution plugin when enabled now only has a second line showing ... "Autoresolution is not working in Scart/DVI-PC Mode ???"
Prior to update it worked fine and I was able to select each resolution independently.
I find the resolution option in AV set-up is far from helpful!!! Especially when you have 1 screen at 2160p capability and the others not (1080p)
I realise this is still a pre-release image but any ideas would be welcomed.
Thanks ...
Nitemare
found this line on the recent 0.6.24 release ...
if (config.av.videoport.value in config.av.videomode and config.av.autores.value == 'disabled') or config.av.videoport.value == 'Scart':
Surely the Scart entry should read HDMI???
Ev0
Admin
We will look into it later.
Right now it is not a priority i'm afraid, as this is an external (not to mention very old) plugin.
Nitemare
Thanks Evo ...
Yes its old ... BUT it does/did work ... ;)
Also while your there ... my wireless Logitech K400 keyboard no longer appears to be recognised in this image? Can you also put this issue on the "to do" list???
Thanks again ...:thanks:
Ev0
Admin
Tbh I can not see any reason why it has stopped working.
The line of code you posted has always been there, so it's nothing to do with that.
Nitemare
Obviously I'm not a coder like you so I'm in dark there ...
Yes Shame it's not working as I find it invaluable ...
