OpenBH 1.0 crashes after choosing channel from history
gulipin
Everytime, when I try to choose channel from the history enigma crashes. What I do is:
* push < or > on remote control
* move down or up to choose desired channel
* push OK on remote and...
... it crashes every single time.
Do you use image with the default skin
without the addition of plugins?
My test with uno 4K no crashes.
Normal skin without addition. But I thought it's Duo2 image section. There might be differences between Uno 4K and Duo2.
Nothing special here...
< 93734.306> [eDVBServicePlay] timeshift
< 93784.428> [eInputDeviceInit] 1 19c 1
< 93784.429> [InfoBarGenerics] KEY: 412 ARROWLEFT
< 93784.451> [ActionMap] InfobarChannelSelection historyBack
< 93784.465> refstr: 1:0:1:3779:44C:13E:820000:0:0:0:
< 93784.469> refstr: 1:0:1:3DD6:640:13E:820000:0:0:0:
< 93784.472> [Skin] processing screen HistoryZapSelector:
< 93784.487> [Skin] processing screen SimpleSummary:
< 93784.765> [eInputDeviceInit] 0 19c 1
< 93784.766> [InfoBarGenerics] KEY: 412 ARROWLEFT
< 93786.653> [eInputDeviceInit] 1 160 1
< 93786.654> [InfoBarGenerics] KEY: 352 OK
< 93786.655> [ActionMap] OkCancelActions ok
< 93786.683> Traceback (most recent call last):
< 93786.683>   File "/usr/lib/enigma2/python/mytest.py", line 230, in processDelay
< 93786.683>     callback(*retval)
< 93786.683>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 2348, in historyMenuClosed
< 93786.684>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 2306, in setHistoryPath
< 93786.684> TypeError: playService() got an unexpected keyword argument 'adjust'
< 93786.684> [ePyObject] (CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x5f157c38>>,()) failed)
I do not know what is the reason for your problem.
Maybe SAT list or corrupted image.
In any case I have not found this problem on my box.
Looks like something corrupt in your image.
Did you restore an old backup or something ?
I downloaded OBH image 1.0.009 from this forum and installed it on Duo2. Everything worked excellently including all plugins installed. It wasn't a problem for me to edit the channel list. Then I upgraded to 1.0.020 and everytime that I tried to edit the channel list, it crashed. I changed the skin to default and it crashed the same. I went back to 1.0.009 and am having no problems with editing channel list. Still I wish that I could keep my Duo2 upgraded to the latest updates and any help will be appreciated. Here is the Crashlog:
OpenBh Enigma2 Crashlog
Crashdate = Tue Jun 20 11:08:56 2017
Creator = OpenBH
Version = 1.0
Build = 020
Type = release
Machine = vuduo2
URL = http://www.vuplus-community.net
Compiled = Jun 18 2017
Skin = skin.xml
Component = Enigma2
Kernel CMDline = libata.force=1:1.5Gbps bmem=192M@64M bmem=384M@512M memc1=788M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync
Nim Sockets = NIM Socket 0:
    Type: DVB-S2
    Name: Vuplus DVB-S NIM(AVL6222)
    Frontend_Device: 0
    I2C_Device: 2
NIM Socket 1:
    Type: DVB-S2
    Frontend_Device: 1
    I2C_Device: 2
5, apid=026d
<  1975.936> [eDVBPCR0] DMX_SET_PES_FILTER pid=0x01f5 ok
<  1975.936> [eDVBPCR0] DEMUX_START ok
<  1975.940> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x026d ok
<  1975.940> [eDVBAudio0] DEMUX_START ok
<  1975.940> [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
<  1975.945> [eDVBAudio0] AUDIO_PAUSE ok
<  1975.947> [eDVBAudio0] AUDIO_PLAY ok
<  1975.953> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
<  1975.953> [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
<  1975.966> [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
<  1975.969> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x01f5 ok
<  1975.969> [eDVBVideo0] DEMUX_START ok
<  1975.969> [eDVBVideo0] VIDEO_FREEZE ok
<  1975.971> [eDVBVideo0] VIDEO_PLAY ok
<  1975.979> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
<  1975.982> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
<  1975.985> [eDVBVideo0] VIDEO_CONTINUE ok
<  1975.988> [eDVBAudio0] AUDIO_CONTINUE ok
<  1975.994> [eDVBAudio0] AUDIO_CHANNEL_SELECT 0 ok
<  1975.997> [eDVBTeletextParser] Starting!
<  1975.997> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
<  1975.997> [eDVBPESReader] Created. Opening demux
<  1975.997> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1975.997> [eDVBTeletextParser] created teletext subtitle PES reader!
<  1975.997> [eDVBTeletextParser] starting PES reader on pid=ffffffff
<  1975.998> [eDVBServicePlay] timeshift
<  1975.999> [eDVBServicePlay] timeshift
<  1976.002> [eDVBServicePlay] timeshift
<  1976.004> [eDVBServicePlay] timeshift
<  1976.334> [eDVBCAService] new service 1:0:1:D49:1450:13E:820000:0:0:0:
<  1976.335> [eDVBCAService] add demux 0 to slot 0 service 1:0:1:D49:1450:13E:820000:0:0:0:
<  1976.335> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.335> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  1976.360> [eDVBServicePlay] timeshift
<  1976.411> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.411> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  1976.415> [Notifications] RemovePopup, id = ZapError
<  1976.415> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.415> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  1976.417> [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 1920x1080 aspect 3
<  1976.436> [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 1
<  1976.438> [eDVBServicePMTHandler] PATready
<  1976.438> [eDVBServicePMTHandler] use pmtpid 044d for service_id 0d49
<  1976.438> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.438> [eDVBSectionReader] DMX_SET_FILTER pid=1101
<  1976.438> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  1976.444> [eDVBFrontend] update current rotorparams 1435 e00b 130
<  1976.444> [eDVBFrontend] set sequence pos 4
<  1976.444> [eDVBFrontend] update current switch params
<  1976.445> [eDVBFrontend] sleep 500ms
<  1976.446> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
<  1976.448> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.448> [eDVBSectionReader] DMX_SET_FILTER pid=6008
<  1976.449> [eDVBServicePlay] have 1 video stream(s) (01f5), and 3 audio stream(s) (0259, 0263, 026d), and the pcr pid is 01f5, and the text pid is ffffffff
<  1976.450> [eTSMPEGDecoder] decoder state: play, vpid=01f5, apid=026d
<  1976.450> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
<  1976.453> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
<  1976.457> [eDVBVideo0] VIDEO_CONTINUE ok
<  1976.460> [eDVBAudio0] AUDIO_CONTINUE ok
<  1976.470> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.470> [eDVBSectionReader] DMX_SET_FILTER pid=6008
<  1976.799> [eDVBCIInterfaces] gotPMT
<  1976.800> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.800> [eDVBSectionReader] DMX_SET_FILTER pid=1101
<  1976.872> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.872> [eDVBSectionReader] DMX_SET_FILTER pid=1101
<  1976.873> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1976.873> [eDVBSectionReader] DMX_SET_FILTER pid=17
<  1977.931> [eDVBServicePlay] timeshift
<  1977.937> [eEPGCache] start caching events(1497949727)
<  1977.937> [eDVBSectionReader] DMX_SET_FILTER pid=3842
<  1977.938> [eDVBSectionReader] DMX_SET_FILTER pid=3003
<  1977.939> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  1977.940> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  1977.941> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  1977.943> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  1977.944> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  1977.945> [eDVBSectionReader] DMX_SET_FILTER pid=5000
<  1977.946> [eDVBSectionReader] DMX_SET_FILTER pid=57
<  1978.077> [eDVBVideo0] VIDEO_GET_EVENT SIZE_CHANGED 1920x1080 aspect 3
<  1978.153> [eDVBVideo0] VIDEO_GET_EVENT PROGRESSIVE_CHANGED 0
<  1978.155> [eDVBServicePMTHandler] AITready
<  1978.155> [eDVBServicePMTHandler] AIT: Rai News
<  1978.156> [eDVBServicePMTHandler] AIT: RaiPlay
<  1978.156> [eDVBServicePMTHandler] AIT: TGR
<  1978.156> [eDVBServicePMTHandler] AIT: Telecomando
<  1978.156> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.156> [eDVBSectionReader] DMX_SET_FILTER pid=3010
<  1978.158> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.158> [eDVBSectionReader] DMX_SET_FILTER pid=1102
<  1978.171> [Dish] tuned, closing...
<  1978.203> [eDVBFrontend] set dynamic current limiting
<  1978.204> [eDVBServicePlay] timeshift
<  1978.237> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.237> [eDVBSectionReader] DMX_SET_FILTER pid=1103
<  1978.308> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.308> [eDVBSectionReader] DMX_SET_FILTER pid=1104
<  1978.321> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.321> [eDVBSectionReader] DMX_SET_FILTER pid=1105
<  1978.408> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1978.408> [eDVBSectionReader] DMX_SET_FILTER pid=1106
<  1978.428> [eDVBServicePMTHandler] OCready
<  1978.447> [eInputDeviceInit] 1 6c 1
<  1978.448> [InfoBarGenerics] KEY: 108 DOWN
<  1978.658> [VideoHardware] setting aspect: 16:9
<  1978.659> [VideoHardware] setting wss: auto
<  1978.660> [VideoHardware] setting policy: bestfit
<  1978.660> [VideoHardware] setting policy2: scale
<  1978.679> [eInputDeviceInit] 0 6c 1
<  1978.680> [InfoBarGenerics] KEY: 108 DOWN
<  1978.726> [ActionMap] InfobarChannelSelection switchChannelDown
<  1978.747> [Skin] processing screen ChannelSelection_summary:
<  1978.980> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1978.991> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1978.997> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1978.998> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.004> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.017> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.027> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.039> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.050> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.061> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.072> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.084> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.093> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.104> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.115> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.203> [eDVBServicePlay] timeshift
<  1979.204> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  1979.204> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  1979.226> [eDVBServicePMTHandler] sdt update done!
<  1979.318> [eInputDeviceInit] 1 67 1
<  1979.319> [InfoBarGenerics] KEY: 103 UP
<  1979.320> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.324> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.331> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1979.549> [eInputDeviceInit] 0 67 1
<  1979.550> [InfoBarGenerics] KEY: 103 UP
<  1980.685> [eDVBServicePlay] timeshift
<  1980.686> [eDVBServicePlay] timeshift
<  1980.822> [eInputDeviceInit] 1 6c 1
<  1980.823> [InfoBarGenerics] KEY: 108 DOWN
<  1980.824> [eInputDeviceInit] 0 6c 1
<  1980.830> [InfoBarGenerics] KEY: 108 DOWN
<  1980.831> [eInputDeviceInit] 1 ae 1
<  1980.832> [InfoBarGenerics] KEY: 174 EXIT
<  1980.834> [ActionMap] OkCancelActions cancel
<  1980.871> [eDVBLocalTimerHandler] diff is 0
<  1980.871> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  1980.871> [eDVBLocalTimerHandler] not changed
<  1980.871> [eDVBChannel] getDemux cap=00
<  1980.933> [eDVBServicePlay] timeshift
<  1980.950> [eInputDeviceInit] 0 ae 1
<  1980.951> [InfoBarGenerics] KEY: 174 EXIT
<  1981.802> [eInputDeviceInit] 1 67 1
<  1981.803> [InfoBarGenerics] KEY: 103 UP
<  1982.033> [eInputDeviceInit] 0 67 1
<  1982.034> [InfoBarGenerics] KEY: 103 UP
<  1982.064> [ActionMap] InfobarChannelSelection switchChannelUp
<  1982.078> [Skin] processing screen ChannelSelection_summary:
<  1982.328> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.338> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.343> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.349> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.360> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.370> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.381> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.391> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.402> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.413> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.425> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.432> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.442> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1982.451> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  1984.411> [eInputDeviceInit] 1 6c 1
<  1984.412> [InfoBarGenerics] KEY: 108 DOWN
<  1984.643> [eInputDeviceInit] 0 6c 1
<  1984.644> [InfoBarGenerics] KEY: 108 DOWN
<  1984.947> [eEPGCache] abort non avail virgin nownext reading
<  1984.948> [eEPGCache] abort non avail virgin schedule reading
<  1984.948> [eEPGCache] abort non avail netmed schedule reading
<  1984.949> [eEPGCache] abort non avail netmed schedule other reading
<  1984.949> [eEPGCache] abort non avail FreeSat schedule_other reading
<  1984.950> [eEPGCache] abort non avail viasat reading
<  1986.574> [eInputDeviceInit] 1 8b 1
<  1986.575> [InfoBarGenerics] KEY: 139 MENU
<  1986.576> [ActionMap] ChannelSelectEditActions contextMenu
<  1986.592> Traceback (most recent call last):
<  1986.592>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 1015, in action
<  1986.592>   File "/usr/lib/enigma2/python/Components/ActionMap.py", line 48, in action
<  1986.593>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 1404, in doContext
<  1986.594>   File "/usr/lib/enigma2/python/mytest.py", line 321, in openWithCallback
<  1986.594>     dlg = self.open(screen, *arguments, **kwargs)
<  1986.594>   File "/usr/lib/enigma2/python/mytest.py", line 331, in open
<  1986.595>     dlg = self.current_dialog = self.instantiateDialog(screen, *arguments, **kwargs)
<  1986.595>   File "/usr/lib/enigma2/python/mytest.py", line 268, in instantiateDialog
<  1986.595>     return self.doInstantiateDialog(screen, arguments, kwargs, self.desktop)
<  1986.595>   File "/usr/lib/enigma2/python/mytest.py", line 291, in doInstantiateDialog
<  1986.596>     dlg = screen(self, *arguments, **kwargs)
<  1986.596>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 229, in __init__
<  1986.597> TypeError: _append_when_current_valid() takes at least 4 arguments (5 given)
<  1986.597> [ePyObject] (CallObject(<bound method ChannelSelectionEditActionMap.action of <Screens.ChannelSelection.ChannelSelectionEditActionMap instance at 0x580ae3f0>>,('ChannelSelectEditActions', 'contextMenu')) failed)
Creator = OpenBH
Version = 1.0
Build = 020
Type = release
Machine = vuduo2
Skin = skin.xml
Component = Enigma2
Type: DVB-S2
Frontend_Device: 0
I2C_Device: 2
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
I2C_Device: 2
5, apid=026d
What kind of channel edit ?
Which buttons actions do you perform before crash ??
Just found out that it does it also on my restored 1.0.0.33 so here's the log
Crashdate = ven. sept. 29 23:59:44 2017
Creator = OpenBH
Version = 1.0
Build = 033
Type = release
Machine = vuduo2
Compiled = Sep 20 2017
Skin = MX_Titanium_C/skin.xml
Component = Enigma2
    Type: DVB-S2
    Frontend_Device: 0
    I2C_Device: 2
NIM Socket 1:
    Type: DVB-S2
    Frontend_Device: 1
    I2C_Device: 2
NIM Socket 2:
    Type: DVB-T
    Frontend_Device: 2
<  5003.539> [gAccel] alloc failed
<  5003.539> [gSurface] ERROR: accelAlloc failed
<  5003.542> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.544> [gAccel] alloc failed
<  5003.544> [gSurface] ERROR: accelAlloc failed
<  5003.548> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.549> [gAccel] alloc failed
<  5003.549> [gSurface] ERROR: accelAlloc failed
<  5003.556> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.556> [gAccel] alloc failed
<  5003.556> [gSurface] ERROR: accelAlloc failed
<  5003.560> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.561> [gAccel] alloc failed
<  5003.561> [gSurface] ERROR: accelAlloc failed
<  5003.566> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.567> [gAccel] alloc failed
<  5003.567> [gSurface] ERROR: accelAlloc failed
<  5003.571> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.571> [gAccel] alloc failed
<  5003.572> [gSurface] ERROR: accelAlloc failed
<  5003.576> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.577> [gAccel] alloc failed
<  5003.577> [gSurface] ERROR: accelAlloc failed
<  5003.582> [eDVBFrontend] isCompatibleWith system 0 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5003.582> [gAccel] alloc failed
<  5003.582> [gSurface] ERROR: accelAlloc failed
<  5003.736> [eInputDeviceInit] 0 69 1
<  5003.737> [InfoBarGenerics] KEY: 105 LEFT
<  5004.356> [eInputDeviceInit] 1 160 1
<  5004.357> [InfoBarGenerics] KEY: 352 OK
<  5004.358> [ActionMap] OkCancelActions ok
<  5004.360> [Navigation] playing 1:0:19:7531:426:1:C00000:0:0:0::MOVISTAR F1 HD
<  5004.361> [eDVBCAService] free slot 0 demux 0 for service 1:0:1:101:1:20FA:EEEE0000:0:0:0:
<  5004.361> [eDVBCAService] free service 1:0:1:101:1:20FA:EEEE0000:0:0:0:
<  5004.389> [eDVBServicePlay] timeshift
<  5004.390> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.392> [eDVBServicePlay] timeshift
<  5004.394> [eTSMPEGDecoder] decoder state: play, vpid=ffffffff, apid=ffffffff
<  5004.394> [eDVBPCR0] DEMUX_STOP ok
<  5004.394> [eDVBPCR0] destroy
<  5004.394> [eDVBVideo0] DEMUX_STOP  ok
<  5004.395> [eDVBVideo0] VIDEO_STOP ok
<  5004.398> [eDVBVideo0] destroy
<  5004.398> [eDVBAudio0] AUDIO_STOP ok
<  5004.423> [eDVBAudio0] DEMUX_STOP ok
<  5004.423> [eDVBAudio0] AUDIO_CONTINUE ok
<  5004.429> [eDVBAudio0] destroy
<  5004.432> [eDVBResourceManager] start release channel timer
<  5004.436> [gAccel] alloc failed
<  5004.436> [gSurface] ERROR: accelAlloc failed
<  5004.459> [eDVBServicePlay] timeshift
<  5004.460> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.462> [eDVBServicePlay] timeshift
<  5004.463> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.464> [eDVBServicePlay] timeshift
<  5004.465> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.467> [Notifications] RemovePopup, id = ZapError
<  5004.468> [eDVBLocalTimerHandler] remove channel 0x17fc238
<  5004.469> [eEPGCache] remove channel 0x17fc238
<  5004.479> [eDVBResourceManager] allocate channel.. 0426:0001
<  5004.479> [eDVBFrontend] isCompatibleWith system 1 is_id -1 pls_code 1 pls_mode 0 is_multistream 0
<  5004.479> [eDVBResourceManager] allocateFrontend, score=115005
<  5004.479> [eDVBResourceManager] allocateFrontend, score=15005
<  5004.479> [eDVBFrontend] opening frontend 0
<  5004.536> [eDVBFrontend] (0)tune
<  5004.536> [eDVBSatelliteEquipmentControl] RotorCmd ffffffff, lastRotorCmd ffffffff
<  5004.536> [eDVBFrontend] prepare_sat System 1 Freq 10906000 Pol 1 SR 22000000 INV 2 FEC 2 orbpos 192 system 1 modulation 2 pilot 2, rolloff 0, is_id -1, pls_mode 0, pls_code 1
<  5004.536> [eDVBFrontend] tuning to 1156 mhz
<  5004.536> [eDVBChannel] OURSTATE: tuning
<  5004.536> [eDVBServicePMTHandler] allocate Channel: res 0
<  5004.536> [eDVBCIInterfaces] addPMTHandler 1:0:19:7531:426:1:C00000:0:0:0::MOVISTAR F1 HD
<  5004.536> [eDVBChannel] getDemux cap=00
<  5004.536> [eDVBResourceManager] allocate demux cap=00
<  5004.536> [eDVBResourceManager] allocating demux adapter=0, demux=0, source=2 fesource=0
<  5004.536> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5004.556> [eInputDeviceInit] 0 160 1
<  5004.557> [InfoBarGenerics] KEY: 352 OK
<  5004.559> [eDVBFrontend] set static current limiting
<  5004.572> [eDVBServicePlay] timeshift
<  5004.593> [eDVBFrontend] invalidate current switch params
<  5004.594> [eDVBFrontend] setVoltage 1
<  5004.620> [eDVBFrontend] sleep 10ms
<  5004.630> [eDVBFrontend] set sequence pos 3
<  5004.630> [eDVBFrontend] update current switch params
<  5004.630> [eDVBFrontend] startTuneTimeout 5000
<  5004.630> [eDVBFrontend] setFrontend 1
<  5004.630> [eDVBFrontend] setting frontend 0
<  5004.680> [eDVBFrontend] (0)fe event: status 0, inversion off, m_tuning 1
<  5004.680> [eDVBFrontend] sleep 500ms
<  5004.864> [eDVBFrontend] (0)fe event: status 1f, inversion off, m_tuning 2
<  5004.864> [eDVBChannel] OURSTATE: ok
<  5004.864> [eDVBLocalTimerHandler] channel 0x1832368 running
<  5004.864> [eDVBChannel] getDemux cap=00
<  5004.864> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5004.864> [eDVBSectionReader] DMX_SET_FILTER pid=20
<  5004.865> [eEPGCache] channel 0x1832368 running
<  5004.865> [eDVBChannel] getDemux cap=00
<  5004.865> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5004.865> [eDVBResourceManager] stop release channel timer
<  5004.865> [eDVBChannel] getDemux cap=01
<  5004.865> [eDVBResourceManager] allocate demux cap=01
<  5004.865> [eDVBResourceManager] allocating shared demux adapter=0, demux=0, source=0
<  5004.865> [eDVBServicePMTHandler] ok ... now we start!!
<  5004.865> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
<  5004.865> [eDVBServicePlay] have 1 video stream(s) (00a0), and 1 audio stream(s) (0050), and the pcr pid is 00a0, and the text pid is ffffffff
<  5004.866> [eEPGCache] next update in 2 sec
<  5004.870> [eTSMPEGDecoder] decoder state: play, vpid=00a0, apid=0050
<  5004.870> [eDVBPCR0] DMX_SET_PES_FILTER pid=0x00a0 ok
<  5004.870> [eDVBPCR0] DEMUX_START ok
<  5004.874> [eDVBAudio0] DMX_SET_PES_FILTER pid=0x0050 ok
<  5004.874> [eDVBAudio0] DEMUX_START ok
<  5004.874> [eDVBAudio0] AUDIO_SET_BYPASS bypass=1 ok
<  5004.880> [eDVBAudio0] AUDIO_PAUSE ok
<  5004.882> [eDVBAudio0] AUDIO_PLAY ok
<  5004.887> [eDVBVideo] Video Device: /dev/dvb/adapter0/video0
<  5004.887> [eDVBVideo] demux device: /dev/dvb/adapter0/demux0
<  5004.890> [eDVBVideo0] VIDEO_SET_STREAMTYPE 1 - ok
<  5004.893> [eDVBVideo0] DMX_SET_PES_FILTER pid=0x00a0 ok
<  5004.893> [eDVBVideo0] DEMUX_START ok
<  5004.893> [eDVBVideo0] VIDEO_FREEZE ok
<  5004.896> [eDVBVideo0] VIDEO_PLAY ok
<  5004.904> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
<  5004.907> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
<  5004.910> [eDVBVideo0] VIDEO_CONTINUE ok
<  5004.913> [eDVBAudio0] AUDIO_CONTINUE ok
<  5004.919> [eDVBTeletextParser] Starting!
<  5004.919> [eDVBTeletextParser] disable teletext subtitles page ffffffffffffffff (und)
<  5004.919> [eDVBPESReader] Created. Opening demux
<  5004.919> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5004.919> [eDVBTeletextParser] created teletext subtitle PES reader!
<  5004.919> [eDVBTeletextParser] starting PES reader on pid=ffffffff
<  5004.920> [eDVBServicePlay] timeshift
<  5004.921> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.921> [eDVBServicePlay] timeshift
<  5004.923> [eDVBServicePlay] timeshift
<  5004.924> [eDVBServicePlay] timeshift
<  5004.925> [Pixmap] setPixmapNum(0) failed! defined pixmaps: []
<  5004.925> [eDVBServicePlay] timeshift
<  5005.051> [eDVBCAService] new service 1:0:19:7531:426:1:C00000:0:0:0::MOVISTAR F1 HD
<  5005.051> [eDVBCAService] add demux 0 to slot 0 service 1:0:19:7531:426:1:C00000:0:0:0::MOVISTAR F1 HD
<  5005.051> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.051> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5005.070> [eDVBServicePlay] timeshift
<  5005.109> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.109> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5005.116> [Notifications] RemovePopup, id = ZapError
<  5005.116> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.116> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5005.123> [eDVBServicePMTHandler] PATready
<  5005.123> [eDVBServicePMTHandler] use pmtpid 0400 for service_id 7531
<  5005.123> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.123> [eDVBSectionReader] DMX_SET_FILTER pid=1024
<  5005.123> [eDVBSectionReader] DMX_SET_FILTER pid=0
<  5005.158> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.158> [eDVBSectionReader] DMX_SET_FILTER pid=1024
<  5005.160> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.160> [eDVBSectionReader] DMX_SET_FILTER pid=17
<  5005.180> [eDVBFrontend] set dynamic current limiting
<  5005.196> [eDVBServicePlay] eventNewProgramInfo timeshift_enabled=0 timeshift_active=0
<  5005.198> [eDVBServicePlay] have 1 video stream(s) (00a0), and 2 audio stream(s) (0050, 0051), and the pcr pid is 00a0, and the text pid is ffffffff
<  5005.198> [eTSMPEGDecoder] decoder state: play, vpid=00a0, apid=0050
<  5005.198> [eDVBVideo0] VIDEO_SLOWMOTION 0 ok
<  5005.201> [eDVBVideo0] VIDEO_FAST_FORWARD 0 ok
<  5005.205> [eDVBVideo0] VIDEO_CONTINUE ok
<  5005.208> [eDVBAudio0] AUDIO_CONTINUE ok
<  5005.327> [eDVBCIInterfaces] gotPMT
<  5005.328> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.330> [eDVBSectionReader] DMX_SET_FILTER pid=1024
<  5005.334> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.334> [eDVBSectionReader] DMX_SET_FILTER pid=1025
<  5005.421> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.421> [eDVBSectionReader] DMX_SET_FILTER pid=1026
<  5005.446> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.446> [eDVBSectionReader] DMX_SET_FILTER pid=1027
<  5005.471> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.471> [eDVBSectionReader] DMX_SET_FILTER pid=1028
<  5005.546> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.546> [eDVBSectionReader] DMX_SET_FILTER pid=1029
<  5005.571> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5005.571> [eDVBSectionReader] DMX_SET_FILTER pid=1030
<  5005.639> [Dish] tuning failed
<  5005.667> [eDVBServicePlay] timeshift
<  5005.668> [eDVBServicePlay] timeshift
<  5005.825> [eDVBServicePMTHandler] sdt update done!
<  5006.071> [eDVBServicePlay] timeshift
<  5006.166> [eDVBLocalTimerHandler] diff is 0
<  5006.166> [eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
<  5006.166> [eDVBLocalTimerHandler] not changed
<  5006.167> [eDVBChannel] getDemux cap=00
<  5006.875> [eEPGCache] start caching events(1506722351)
<  5006.875> [eDVBSectionReader] DMX_SET_FILTER pid=211
<  5006.875> [eDVBSectionReader] DMX_SET_FILTER pid=561
<  5006.875> [eDVBSectionReader] DMX_SET_FILTER pid=3842
<  5006.876> [eDVBSectionReader] DMX_SET_FILTER pid=3003
<  5006.876> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5006.877> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5006.879> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5006.880> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  5006.881> [eDVBSectionReader] DMX_SET_FILTER pid=700
<  5006.882> [eDVBSectionReader] DMX_SET_FILTER pid=5000
<  5006.883> [eDVBSectionReader] DMX_SET_FILTER pid=5000
<  5006.884> [eDVBSectionReader] DMX_SET_FILTER pid=57
<  5007.479> [eDVBFrontend] close frontend 2
<  5007.479> [eDVBFrontend] sendTone allowed only in feSatellite (2)
<  5009.278> [eDVBServicePlay] timeshift
<  5009.279> [eDVBDemux] open demux /dev/dvb/adapter0/demux0
<  5009.279> [eDVBSectionReader] DMX_SET_FILTER pid=18
<  5009.706> [eDVBServicePlay] timeshift
<  5010.304> [eDVBServicePlay] timeshift
<  5013.884> [eEPGCache] abort non avail schedule reading
<  5013.886> [eEPGCache] abort non avail schedule other reading
<  5013.887> [eEPGCache] abort non avail virgin nownext reading
<  5013.888> [eEPGCache] abort non avail virgin schedule reading
<  5013.888> [eEPGCache] abort non avail netmed schedule reading
<  5013.889> [eEPGCache] abort non avail netmed schedule other reading
<  5013.889> [eEPGCache] abort non avail FreeSat schedule_other reading
<  5013.890> [eEPGCache] abort non avail viasat reading
<  5013.890> [eEPGCache] abort non avail mhw reading
<  5013.891> [eEPGCache] nownext finished(1506722358)
<  5013.891> [eEPGCache] stop caching events(1506722358)
<  5013.892> [eEPGCache] next update in 60 min
<  5037.382> [eInputDeviceInit] 1 197 1
<  5037.383> [InfoBarGenerics] KEY: 407 ARROWRIGHT
<  5037.407> [ActionMap] InfobarChannelSelection historyNext
<  5037.419> refstr: 1:0:1:120:1:20FA:EEEE0000:0:0:0:
<  5037.420> [gAccel] alloc failed
<  5037.420> [gSurface] ERROR: accelAlloc failed
<  5037.424> refstr: 1:0:1:101:1:20FA:EEEE0000:0:0:0:
<  5037.426> [gAccel] alloc failed
<  5037.426> [gSurface] ERROR: accelAlloc failed
<  5037.429> refstr: 1:0:19:7531:426:1:C00000:0:0:0::MOVISTAR F1 HD
<  5037.432> [Skin] processing screen HistoryZapSelector:
<  5037.449> [Skin] processing screen SimpleSummary:
<  5037.614> [eInputDeviceInit] 0 197 1
<  5037.615> [InfoBarGenerics] KEY: 407 ARROWRIGHT
<  5039.372> [eInputDeviceInit] 1 6c 1
<  5039.373> [InfoBarGenerics] KEY: 108 DOWN
<  5039.497> [eInputDeviceInit] 0 6c 1
<  5039.498> [InfoBarGenerics] KEY: 108 DOWN
<  5039.762> [eInputDeviceInit] 1 6c 1
<  5039.763> [InfoBarGenerics] KEY: 108 DOWN
<  5039.887> [eInputDeviceInit] 0 6c 1
<  5039.888> [InfoBarGenerics] KEY: 108 DOWN
<  5040.092> [eInputDeviceInit] 1 160 1
<  5040.093> [InfoBarGenerics] KEY: 352 OK
<  5040.094> [ActionMap] OkCancelActions ok
<  5040.121> Traceback (most recent call last):
<  5040.121>   File "/usr/lib/enigma2/python/mytest.py", line 236, in processDelay
<  5040.122>     callback(*retval)
<  5040.122>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 2443, in historyMenuClosed
<  5040.122>   File "/usr/lib/enigma2/python/Screens/ChannelSelection.py", line 2401, in setHistoryPath
<  5040.122> TypeError: playService() got an unexpected keyword argument 'adjust'
<  5040.123> [ePyObject] (CallObject(<bound method Session.processDelay of <__main__.Session instance at 0x5c0c4210>>,()) failed)
