OpenBH 1.0 Vu+ Zero
Ev0
Admin
OpenBH 1.0
1-jpg.30144
Whats New:
  • Updated to OE4.0 core
  • Updated to Python 2.7.12
  • Updated to Gstreamer 1.11.2 (GIT)
  • Automatic backup before online update
  • Option to view changes before online updating
Main Features:
  • MX Titanium_C Full Hd skin (1920x1080)
  • Kodi 17.1 (for those models that support it)
  • Fallback - Fallback tuner settings moved to Service searching menu into its own menu
  • Fallback - Remote bouquets copier (Channel Importer). For receivers used as clients, copies and loads the channel list from the server box.
  • Fallback - ability for client to not write EPG data back to server box. Means epg.dat can be shared over a network mount without fear of corruption.
  • Various OE-A Core updates.
  • Updated Service Info screen
  • Updated Streaming Clients screen (skin dependant)
What is OpenBH ?
It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new OpenBH image ?
No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
2-png.30151
3-jpg.30153
4-jpg.30154
5jpg.30146
6-jpg.30147
7-jpg.30150
8-jpg.30148
9-jpg.30152
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
openbh-1.0.009.release-vuzero_usb_release_52b2ab0.zip
It seems there was a bug in OBH 1.0.001 (the first release) that was not present during testing with full backup.
It has been fixed in 1.0.002 however it seems the fix does not come through via online update for some reason.
Therefore the only option to fix, is to download the new file (attached to release post) and reflash the box (you can use a settings backup to make it quicker to setup the box again).
I've always used "OK" to get to the channel list. Can't find the option for changing this. Where can I change this?
If you press OK ... you should get the info bar ... if you press a 2nd time ... you should get 2nd infobar.
Why don´t you use the up or down arrow buttons on your rcu?
This is new. By default neither BH nor OBH give to you access to channel list by OK. And, anyway, if pressing UP/DOWN to get the list is a big problem, you could try the menu
Setup/System/User Interface/Button Setup
to see if it's possible to change this setting.
For ME is not a big problem, but we've got 6 VU's around the house and with a non-technical wife and handicapped son who both are used to using OK to change channels, it will be a problem. :)
Seems like I'm stuck at OBH 0.4 then...
