OpenBH 4.1 Vu+ Solo2
Ev0
Admin
OpenBH 4.1
1-png.33196
Whats New:
  • Updated to OE4.1 core
  • Updated to Python 2.7.13
  • Updated to Gstreamer 1.13.0
  • Glibc 2.2.5
  • GCC bug fixes
  • openSSL Security fixes
  • Basis for new 64 bit environment Support for multi libs 32/64 Bit
  • Stability updates
  • Based on OE-Core Morty
  • MX BlackShaddow_P Full Hd skin (1920x1080)
  • Kodi 17.6 (for those models that support it)
  • Various OE-A Core updates
2-png.33189
3-jpg.33191
4-jpg.33192
5-jpg.33195
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
hi, is this release an upgrade (Major) of the 1.0 ?
I have Blackhole image 3.04 on my VU+Solo2 and want to install OBH
Thanks
is the "tuner failed" problem fixed or not?
4-jpg.33192
also I see in this picture the frequency in infobar has correct number. has problem fixed too?
Hello, thanks for the new release
Could I load a backup from OpenBH 1.0 to OpenBH 4.1?
No, during installation it will ask if you wish to, but then inform you that the backup is outdated.
The good news is that it will load all your Kodi stuff.
If installing 4.1 backup your channel data, using dreamboxedit.
This is the problem of your satellite installation and not the image.
but it happens to me with openBH and openvix only, on previous images. it happened when I try stream channels through Openwebif with VLC
and also when I use them with Openmultiboot
Is it my subjective impression or the picture quality has gone down slightly with image OpenBh 4.1. The picture is not that sharp the way I see it.
Can I install other images on Vu Solo 2 via openMultiboot Manager on HDD and how?
Of course: why not? Did you read somewhere of any limitations?
Configure OMB the first time you launch it to run from HDD and the upload the images in the upload folder. Shorten the namefiles, remember.
The image is really good. Light and customizable.
However, i miss a feature from BH image.
I have a movies library that is listed as a bouquet in my channel list.
On BH, when I select a movie, it is identified as a movie stream and I can use the stop/play, 3-6-9 buttons to control it (exactly like Mediaportal).
On OBH, the movie is identified as a usual channel and I cannot use the media control buttons above.
Any idea?
What for? In OBH you can even create and manage folders, also within the movie folder, so that you need just to enter the recording list and browse it and then play movies from there. Easy, fast, without any plugin's complication.
