OpenBH 4.1 Vu+ Zero
Ev0
Admin
OpenBH 4.1
1-png.33196
Whats New:
  • Updated to OE4.1 core
  • Updated to Python 2.7.13
  • Updated to Gstreamer 1.13.0
  • Glibc 2.2.5
  • GCC bug fixes
  • openSSL Security fixes
  • Basis for new 64 bit environment Support for multi libs 32/64 Bit
  • Stability updates
  • Based on OE-Core Morty
  • MX BlackShaddow_P Full Hd skin (1920x1080)
  • Kodi 17.6 (for those models that support it)
  • Various OE-A Core updates
2-png.33189
3-jpg.33191
4-jpg.33192
5-jpg.33195
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
gracias evo . por esta buena imagen . pregunta . que tengo que hacer para que funciona . backup suit . en vu+ zero.
Hello, perhaps you received this question many times but is the plugin Kodi not possible with Vu+Zero ?
I have install this image on Vu+Solo2 and Kodi 17 is available by pressing 2 times the blue Button. Does Vu+Zero not support Kodi ?
Thank you
The VU+ Zero was not really produced as a stand alone receiver, more as a second receiver, that links to a main VU+ model, so it hasn't got the power, of other receivers, as you can see by the manufactures specifications, check the link, bottom of the page:
http://www.vuplus.com/sub/sub0102.php
So it can't do as much as the larger VU+ receivers, including handle full Kodi.
I think this account has been hackered: never seen a user with more than 100 posts, spamming. Maybe an @admin can send him a warning?
