OpenBH 4.2 Vu+ SoloSE
Ev0
Admin
OpenBH 4.2
1-png.33196
Whats New:
  • Updated to OE4.2 core
  • The main packages and utilities have been updated:
  • Gstreamer 1.14.4
  • Libc6
  • Openssh
  • Busybox
  • Samba
  • Openssl
  • Nfs Util
  • Dropbear
  • Bitbake
  • Gcc 6.3.0 Memleak fix
  • Based on OE-Core Roki
  • Various OE-A Core updates
  • Various Skin Updates from Mx10
2-png.33189
1-png.39763
2-jpg.39633
3-png.39762
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
Hi,
My solo se is crashing everytime i restart the osc*m. I tryed to restart it because when coming from standby there´s no image. But via webif i can see that osc*am is still runing. Logs attached if it helps
hi
i have installed this one on my vu solo se v2, to see if it solved my remote channel stream proble (but no luck).
Can I now install BH 3.08 back??
i am trying to flash by usb but no luck (using the same pen used to install OBH)
hi
Of course you can
And if you can not, then the problem is in the files
or USB stick
