OpenBH 4.2 Vu+ Uno
Ev0
Admin
OpenBH 4.2
1-png.33196
Whats New:
  • Updated to OE4.2 core
  • The main packages and utilities have been updated:
  • Gstreamer 1.14.4
  • Libc6
  • Openssh
  • Busybox
  • Samba
  • Openssl
  • Nfs Util
  • Dropbear
  • Bitbake
  • Gcc 6.3.0 Memleak fix
  • Based on OE-Core Roki
  • Various OE-A Core updates
  • Various Skin Updates from Mx10
2-png.33189
1-png.39763
2-jpg.39633
3-png.39762
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
after installing vu uno it stuck at beginning and the spinner continue to work to infinite
what is wrong openblackhole team ???
  • Like
Reactions: KFL
seeem you gonna need beta tester for vu uno
i would like to join your team
Beta testers need to be able to make reliable reports, but as the image has been available for 4+ days now, with many users downloading it (not just from this board, but others too) and you are the only one having an issue. It suggests the problem is with your setup and not the image itself.
Besides, we already have enough beta testers in our team for the moment.
I have same problem OBH42 like user crush. Few weeks ago I was testing other images (because was no OBH42 for uno) and one of them has same problem.
I can make ssh connection, some errors there repeated (dmesg, something like VIDEO).
Have you some hint which logs to see? I could try to install OBH42 a see what is wrong/problematic.
If you can ssh into the box, when it fails to boot, type init 2 (press enter) to stop the box.
Then type enigma2 (press enter) and look through the log, to see what the error is and post it here please.
  • Like
Reactions: KFL
OBH 4.2 for Vu+ Uno comes with only german and english languages installed. If you select any other language, box will not boot up.
217.036> [Language] Activating language Eesti
< 217.040> [Language] Selected language does not exist!
< 217.152> [UserInterfacePositioner] Setting 3D mode: auto
< 217.154> [UserInterfacePositioner] Setting 3D depth: 50
< 217.160> Traceback (most recent call last):
< 217.161> File "/usr/lib/enigma2/python/mytest.py", line 627, in <module>
< 217.165> Components.AVSwitch.InitAVSwitch()
< 217.165> File "/usr/lib/enigma2/python/Components/AVSwitch.py", line 378, in InitAVSwitch
< 217.166> NameError: global name 'ngettext' is not defined
What does it mean to me?
For now, use either English or German language and it should work.
I need to find time to look to see why the other languages are not working.
Which language did you have selected ?
If you have image installed and it's does not boot, type in telnet init 4
Ftp to your box, open /etc/enigma2/settings, delete the line which begins config.osd.language and save it
type in telnet init 3
The other languages will crash the box, because /usr/share/enigma2/po contains only de and en folders.
  • Like
Reactions: Ev0
Le problème dans le fichier po avant d'envoyer le fichier avant de lancer l'image sur le chemin de usr / share / enigma2
Test results:
-spinner loop has nothing to do with language. no startup wizard dispalyed, no language dialog displayed, I reboot uno too, nothing changed
init 4
ls /usr/share/enigma2/po
de en
opkg update
opkg upgrade
opkg install enigma2-locale-sk
de en sk
cat /etc/enigma2/settings
cat: can't open '/etc/enigma2/settings': No such file or directory
init 3
-but these messages are repeated continuously
root@vuuno:~# tail -f /var/log/messages
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:08:40 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:08:42 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:08:42 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:08:42 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:08:54 vuuno daemon.notice ntpdate[1088]: adjust time server 193.87.160.18 offset 0.002287 sec
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:08:57 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:08:59 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:08:59 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:08:59 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:09:01 vuuno cron.info crond[671]: (readme.txt) ORPHAN (no passwd entry)
Dec 10 01:09:11 vuuno daemon.notice ntpdate[1123]: adjust time server 62.168.94.161 offset -0.001594 sec
Dec 10 01:09:14 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:09:14 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:09:14 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:09:14 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:09:14 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:09:15 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:09:15 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:09:16 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:09:16 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:09:16 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:09:28 vuuno daemon.notice ntpdate[1157]: adjust time server 62.168.94.161 offset 0.000978 sec
Dec 10 01:09:31 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:09:31 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:09:31 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:09:31 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:09:31 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:09:32 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:09:32 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:09:33 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:09:34 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:09:34 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:09:45 vuuno daemon.notice ntpdate[1190]: adjust time server 193.87.160.18 offset 0.000844 sec
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:09:49 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:09:51 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:09:51 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:09:51 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:09:59 vuuno user.notice kernel: EXT4-fs (sdb1): error count: 683
Dec 10 01:09:59 vuuno user.notice kernel: EXT4-fs (sdb1): initial error at 1484040455: ext4_mb_generate_buddy:749
Dec 10 01:09:59 vuuno user.notice kernel: EXT4-fs (sdb1): last error at 1498688071: ext4_mb_generate_buddy:749
Dec 10 01:10:01 vuuno cron.info crond[671]: (readme.txt) ORPHAN (no passwd entry)
Dec 10 01:10:03 vuuno daemon.notice ntpdate[1224]: adjust time server 62.168.94.161 offset -0.001098 sec
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:10:06 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:10:08 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:10:08 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:10:08 vuuno user.warn kernel: [CI]:ci1_dev_open
Dec 10 01:10:20 vuuno daemon.notice ntpdate[1257]: adjust time server 62.168.94.161 offset 0.000846 sec
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_SET_STREAMTYPE 0
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 1
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_PLAY 1 2 0
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_CONTINUE 1 1
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_CLEAR_BUFFER 1 1 0
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_STOP 0 1
Dec 10 01:10:23 vuuno user.warn kernel: [VID]: VIDEO_SELECT_SOURCE 0
Dec 10 01:10:25 vuuno user.err kernel: [LCD]: unknown cmd 0x1015
Dec 10 01:10:25 vuuno user.warn kernel: [CI]:ci_dev_open
Dec 10 01:10:25 vuuno user.warn kernel: [CI]:ci1_dev_open
^C
For now back to OBH41.
What about this:
< 581.474> File "/usr/lib/enigma2/python/Components/AVSwitch.py", line 380, in InitAVSwitch
< 581.475> NameError: global name 'ngettext' is not defined
for i in range(5, 16):
choicelist.append(('%d' % i, ngettext('%d second', '%d seconds', i) % i))
ngettext is defined in gettext.py
