OpenBH 4.4 Vu+ Solo2
Ev0
Admin
OpenBH 4.4
Whats New:
  • Updated to OE4.4 core
  • The main packages and utilities have been updated
  • Factory reset procedure was overhauled
  • Action controls changed. Use OBH 4.3 if your plugins don't work properly for you
  • EPG buttons customisable. Long press EPG button to change defaults
*** Password is required for FTP, TELNET & SSH ***
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
DOWNLOAD HERE:
It is my opinion that, regardless of what is requested in version 4.4 of the OBH image, it is always advisable to create a password to access the decoder. ;)
Qual è la bandiera che avvia la scansione? Un flag è un segno: forse volevi dire il sottomenu: è in Impostazioni/Tuner & Ricerca canali: dove se no?
La ricerca canali permette solo la scansione su una frequenza, ma non la scansione automatica su tutte le frequenze.
Prima bastava andare sul menù scansione automatica e c'era la possibilità di avviare la scansione. Ora non c'è.
Ma quando mai! La scansione dell'intero satellite sta dove è sempre stata. Sia su scansione automatica, con i multisat, sia in scansione manuale (la più sensata) con la scelta del satellite singolo.
Come si vede nelle foto quella di OBH 4.3 ha la dicitura "Premi OK per ricercare", mentre quella di 4.4 non c'è, per cui non posso fare la scansione. Come si fa a fare la scansione?
1) Dopo tanto tempo da che sei iscritto, invece che farci girare il collo con queste foto da telefono, per di più tutte sfocate, dovresti sapere che il grab di una schermata si può fare semplicemente digitando l'IP del tuo box, seguito da /grab, in un browser qualsiasi (compreso quello del telefono...).
xxx.yyy.www.zzz/grab
e poi salvando l'immagine come qualsiasi altra.
2) Se avessi premuto qualche pulsante a caso, partendo dal più utilizzato come alternativa all'OK, ossia il pulsante VERDE, avresti scoperto al primo colpo che parte la scansione anche in questo modo (e, ripeto, OK e VERDE sono spessissimo abbinati per lanciare i comandi).
3) Il menu della scansione automatica non è indispensabile, come ti ho già scritto: io non l'ho usato quasi mai, per esempio. Perché dover aspettare una ricerca su tutti i satelliti+terrestre quando, al 99% di solito serve trovare qualcosa di nuovo solo su uno di essi?
Ogni tanto faccio una scansione completa, dall'altro menu scansione manuale, sul satellite che m'interessa aggiornare o sul terrestre.
A dir la verità, le scansioni complete le faccio molto di rado: più spesso cerco solo quei transponder per i quali sono disponibili nuovi canali, ammesso che m'interessino, dopo aver consultato KingOfSat o simili.
Come devo fare la ricerca in 4.4.View attachment 50049View attachment 50050
Dovrebbe essere risolto al più presto, al prossimo aggiornamento!
Anche se non lo è, puoi premere il tasto verde ed eseguire la scansione, senza alcun problema!
grazie
Rapidissimi, con l'ultimo aggiornamento ripristinata la possibilità di avviare la scansione dei canali direttamente dalla scansione automatica o manuale.
