OpenBH 4.4 Vu+ Zero & Vu+ Zero Rev.2.0
Ev0
Admin
OpenBH 4.4
Whats New:
  • Updated to OE4.4 core
  • The main packages and utilities have been updated
  • Factory reset procedure was overhauled
  • Action controls changed. Use OBH 4.3 if your plugins don't work properly for you
  • EPG buttons customisable. Long press EPG button to change defaults
*** Password is required for FTP, TELNET & SSH ***
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
DOWNLOAD HERE:
Hello Evo and best team.
thanks for the new OpenBH image. I just played at Vu zero. Everything is going well. I just wanted to install the feed service app. unfortunately it didn't work. It depends on the execution.
Thank you very much
there is a problem installing the service app from the feed. Problems with the Vu Zero 4K as well.
Thank you
Hello Community,
has someone tried to instalieren from the feed service app?
with vu zero and vu zero 4k i still have problems myself.
Thank you
Thank you
Hello Community,
Thank you
Problems? On 2 posts you haven't descrived any!
Wich problems, don't install?
If OBH 4.4 is in flash, unfortunately the built-in OMB does not work, it seems to be installed, but you can not do another image, the system hangs
...I installed it exactly on a USB flash drive, it mentions that at the moment there is version 4.3 in flash and it works right away ...
Well no problem keeping a good working copy of 4.3 in the flash and then install 4.4 in OMB
This is accually a very good way to prep a new image before backing it up and install into the flash.
I can't make the connection, they ask for my password, does anyone know what the password is. thanks
Despite of the BIG, BOLD and RED message, still people don't get it.
Maybe, @admins, is it the case to make it fool-proof, writing something like that?
In the new 4.4 IT'S COMPULSORY TO SET A PASSWORD in order to connect by FTP, TELNET & SSH.
Do it by MENU/Setup/Network/Password
or by telnet/SSH command
passwd
because I'm becoming more and more annoyed by the same question. I must've read it something like 40 times...
Maybe it's better to take it off, I think only the VIX has it!
Inviato dal mio MI 10 utilizzando Tapatalk
What? Surely both OBH 4.4 and ViX 5.4 need a password, now, to get access. Previous version needn't.
In fact, I said that the only Open to which the password must be changed are the OBH and the VIX, the others such as the PLi and the Atv do not have the password "problem".
