OpenBH 4.4 Vu+ Zero4K
Ev0
Admin
OpenBH 4.4
1.jpg​
Whats New:
  • Updated to OE4.4 core
  • The main packages and utilities have been updated
  • Factory reset procedure was overhauled
  • Action controls changed. Use OBH 4.3 if your plugins don't work properly for you
  • EPG buttons customisable. Long press EPG button to change defaults
*** Password is required for FTP, TELNET & SSH ***
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
DOWNLOAD HERE:​
Thanks a lot for the new image, but I have problem with fullbackup because when I try to restore image, my vu+zero4k crash and don’t generate log file in home/root/. I have also problems with parental control because the keyboard don’t type the new pin and last with protocol ssh I don’t have access to the box, but FTP and Telnet it’s ok with my new password. Thanks in advance for your answers.
Yes it's true. Happen samething thing to me when try restore backup vu crash and error say something about skin a think.
You can always unzip the FullBackup from the device you used to create it into a USB flash stick and flash your box in the traditional way.
Hi
I need to help I’m looking to buy for my uno 4K se WiFi usb dangle
Which usb WiFi good for me please let me know thank you
Hi the image is very nice but I have encountered several problems between these OBH update tells me that there is an update available but after the restart it still remains the same update available, the backup restore does not work or better it works only by unpacking the zip archive , even after changing the password the SSH protocol does not work, the Parental Control Pin does not write anything I am attaching the photos to be able to make any remedies, thanks in advance bye
  • Enigma2_crash_2020-11-29_11-54-59.txt
  • Enigma2_crash_2020-11-29_11-50-36.txt
You question is not clear: if you mean how to show the Power Menu, there is nothing to set: this is the default behaviour, nor can be modified.
If you need to customize the long press of PowerButton, it can be customized, as almost every other remote buttons, by the "Button setup" under "User Interface" submenu.
Thank you for your answer. with other image you can set it to switch off, for example standby or direct shutdown. I wanted to change it. for me it's on standby.
thanks
