OpenBh 5.0 Vu+ Uno4K SE
Ev0
Admin
OpenBh 5.0
OpenBh 5.0 is based on the OE-Alliance 5.0 core.
So what is different in OpenBh 5.0 then?
OpenBh 4.4 build 023 was the final build in the 4.4 series.​
The main change from OpenBh 4.4 to OpenBh 5.0 is that Python has been upgraded from Python 2 to Python 3. Python 3 is already 10 years old and Python 2 was deprecated in 2015 and is therefore no longer maintained. This means all the third party packages we use are also no longer maintained. Which means there will be no future updates for security vulnerabilities. Because of this we have no option but to upgrade to Python 3.​
Unlike previous images, the main differences are in both the OpenBh image which has been recoded for Python 3 and the core of the image or the OE (Open Embedded) which has also undergone huge changes, updates and fixes to ONLY support Python 3.
Whats New:
  • OE-A 5.0
  • Python 3.9
  • Extensive changes to meet Python3 requirements.
  • Some plugins may no longer may no longer work, so you will need to contact the plugin authors to ask them to update their plugins for Python3.
Apart from the above you should not notice many differences between previous OpenBh 4.4 and OpenBh 5.0 images.​
*** You need to set a Password to use FTP, TELNET & SSH ***
Where can I find the OpenBh git ?
The OpenBh git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the OpenBh Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBh.
  • Twol for the conversion to Python 3. This has involved manually converting literally hundreds of Python files and associated c++ code.
  • Huevos and Twol for testing, debugging, and responding to feedback and problems.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBh skins.
DISCLAIMER
THE OPENBH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPENBH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
DOWNLOAD HERE:​
I have a problem with Open Black Hole 5 that my engine is not rotating on the selected satellite. the image of the dish flashes indicating the original indication of the satellite and the new one, where it should turn, but does not rotate. I have the tuners set up as I have them in img Black Hole, where there is no such problem. I have black sticks in flash and OBH5 in open multiboot. Could it be that there is no OBH in the flash?
