openBh_InfinityHd_RemyMod (zero_solose_solo2_duo2)
arslanplaza
View attachment 20734 View attachment 20734 hzKOxbY.jpg hi dear members and managers my edit InfinityHD skin
how ı do:
connect via ftp your box first Get a backup of your components file(usr/lib/enigma2/python/components)
and send usr file ftp main screen write on your usr file later your orginal components (backup components)
send to usr/lib/enigma2/python/components write on components , important thing usr/share/enigma2/InfinityHD chmod 755 make and and weather plugin should be installed iff not it plugin first installed later skin installed
skin download
weather plugin download(usr-lib-enigma2-python-plugin içine atın)
burada da teşekkür edeyim remzi arkadaşım ben weather plugini beceremedim yav ,okyanusu geçtik derede boğulduk misali oldu benimkisi
You must make chmod755 your plugin weather plugin and you must weather plugin open and add your current location and ok , later weite your location again and it worker
Sent from my iPhone 6
For me not working..Vu duo2..i did all step by step..box hang on boot...
hi pedras,
1) did you make usr/share/enigma2/InfinityHD chmod 755 ?
2) weather plugins chmod 755
3)your orginal components (your backup components) again send to python
4)you see fonts file my usr/share/ fonts copy and send your box usr/share/
and again start your box we did try all box work best regards
hi pedras,
Thanks Arslanplaza..is working fine now..great Skin
