OpenMultiboot BH 3.0.3h not starting
soduso
So I've decided to upgrade my Vu+Uno from 2.1.7. to version 3. Having read about low internal flash memory, I went through the whole OpenMultiboot story and succesfully installed OM into usb stick and subsequently the BH 3.0.3H. However after restaring the box and choosing the 3.0.3H image to load I am stucked with the black screen and the display reads Vu+Uno and nothing happens for quite a long time. I am able restart and choose the flash version (2.1.7.) but I wonder if I did something wrong. Any ideas please?
Thanks
I've uploaded OpenBH image instead and everything works like it should. Could it be that my tv simply did not recognize AV setting ov BH3? We will never know.
Try again and the advice is to rename the zip file of the image you put in the openmultiboot upload folder as shorter as possible. For instance, you might name it as BH.zip.
So, delete the installed image from OMB menu, re-upload and reinstall. As now we have 3.0.4, you can leave the 303 to the past.
