OpenMultiboot Vu+Uno4kse
Hi i have a strange problem with open multiboot
I have OpenBlackhole in flash as recommende and Blackhole 3.0.5 in multiboot
I do some privite only skinning (Learning from the maste Matrix 10 ) :)
So i decided to install a copy of OpenBlackhole in multiboot since i am a newbie and crashing up a lot as i slowley getting the hang of skinning.
The problem i have with OpenMultiboot is that i cant boot in to the OpenBlackhole in multiboot
Get the menu and chosing OpenBlackhole from boot menu and get the Blackhole start screen.
But no boot stops back a few times in boot menu and then chrash. I have reflashed to see if that helps
but no luck,
When i boot up back in to the flash and open Multiboot manager i can se Flash image and all other images
including the OpenBlackhole image in multiboot. But the manager is showing info "In the Flash" on both images
And the delete button is turned off for the OpenBlackhole image thats in multiboot.
Maybe there is a bug so Multiboot cant seperate flash image from multiboot image when they are the same.
In my Vu+ Solo2 there is no problem i can have as many OpenBlackhole images i want in multiboot
Would be happy if there is a fix for this :)
Interesting. I'll try myself a second installation of OBH also in omb as soon as possible. Meanwhile, you could try to delete, by FTP, the subfolder related to the OBH in omb. It'll be within
/media/xxx/open-multiboot
where xxx is usb or hdd, depending on your omb location.
Then, try to reinstall.
Hi tanks for your answer
I have allredy tried that and also try to change name on the multiboot image but no luck
So waiting for you to do some test
Hi there is no crashlog generated all is happening in multiboot startup menu.
Flash Image first line
OpenBlackhole 4.1 second line
Blackhole 3.0.5 third line
I can scroll throug the menu an select any image but when selecting OBH i get reboot screen as a supose to
but then i get boot up menu again. If i try several times finaly evering goes black on TV and Bootscreen "BlackHole" in minitv display.
Power of an on and i can boot up anything i want exept OBH Multiboot.
In OBH manager both Flash Image and OBH image in multiboot is shown as they are in the flash
so OMB can not see the diffrence betwen to identical images if one is in Flash and the other in OMB is what i guessing
And as i said in my earlier post
Same setup on my Vu+ Solo2 work perfect
Are you using a backup in OpenMultiboot? This could be the cause ... the kernel could be corrupted.
I have tried both option
First with an backup of my flash image but when that did not work i come to the same conclusion and downloaded new fresh image from this site
But same issu with that also
Regards Thomas
Regards Thomas
I am currently running OpenBlackHole 4.1.023 on my uno4k se, as also, on Ultimo4k, Zero4k and Duo2, and in all of them i have no issues running OpenBlackHole 4.1, BlackHole 3.05, OpenVix, OpenATV, OpenSpa on OpenMultiboot.
In all USB devices i use EXT4 file system. Are you using the same FS also?
I just can say, i have only issues if i install OpenPli or Vti images on OpenMultiboot.
Have filesystem EXT4 on scandisk 32gb usb stick
I have OpenPli 6 installed in multiboot so will try and delete that and see if maybe that is the problem :)
I whent back to the god old Blackhole Image in the flash and now installed one fresh copy of OBH in OMB and one Backup copy and evrything works just perfect :)
Since its looks like its only me who have this problem since noby else has report it i think it something with my usb stick that OBH and OMB dont like even if its a known brand and usb 2.0
I will try your suggestion later and se if its solve my problem
Many thanks for good support
regards Thomas
Ok a little update
1. Flashed my box with OBH 4.1.009 installed from scratch channel list and manual tuner config.
2. installed OBH same image in OMB and working fine
3. to check installed another copy now from backup of same image (My first in the flash) working fine
4. Installed Latest Blackhole working fine
5. Did online update on OBH in Flash and now everything stops working only OBH in flash and Blackhole in OMB booting up
Image OBH in multiboot dont boot up
6. making backup of OBH Flash image and upload to OMB and that image works ;) so something in OMB dont like when version in the flash in newer then version in OMB
Did all again as described above but this time i online update image in OMB before image in the flash and all works 100% fine
So for people with my same problem. Update multiboot image allways first then you dont get this problem :)
Thanks for all the help and thanks for good image work
Ok a little update
Just one appointement:
I don´t know why you have flashed your STB Open BlackHole 4.1.009, when you have a newer version on our board --> Open BlackHole 4.1.018
Take a look at the images section. --> http://www.vuplus-community.net/board/threads/openbh-4-1-vu-uno4k-se.35563/
Anyway, thanks @Thomas67
I only chose that image because thats the one i downloaded when i did bu my Uno4Kse and it was easy to just flash with that
so maybe an old guy needs to learn some new habits ;) anyway many thanks for good support :)
So, I finally did the same try in my SOLO4K (but, obviously, starting from 4.1.018, the last available package...).
In flash there was the 4.1.022 updated to yesterday last updates.
Everything went fine with installing the .018. Then I updated it online to .022 and no problem at all: every images are selectable either in the plugin menu or in the boot menu and they both work fine.
The question arises, how critical is it to online update the image in FLASH regularly? Most use their the day to day image in OMB and just online update that when updates are available.
I have Open BlackHole installed in flash, although the same image is installed too on Open Multiboot.
When i noticed that update images are available, i allways update the flash image and then the image running on Open Multiboot.
Instead I use Automatic Fullbackup (which I prefer to the OBH function) and it is scheduled to perform a backup on a daily basis during the night. So,if something goes wrong with an update, I can go back easily. And even if should I realise an issue many days later, I would be able to get back to whatever day
